SYS FLASHING ON SPEEDOMETER SCREEN
Old Sep 25, 2003 | 09:10 AM
mjfox's Avatar
mjfox
Default SYS FLASHING ON SPEEDOMETER SCREEN
i HAD A PROBLEM STARTING MY CAR BOOSTED IT IT STARTED ,THEN THE NEXT DAY I HAD SYS FLASHING ON MY SPEEDOMETER AREA THEN NEXT LOW VOLTAGE IN MILEAGE AREA .DECIDED TO CHECK THE CODES HAVE A CODE 16 STORED .
sTUMPED
THANKS MIKE
Old Sep 25, 2003 | 10:16 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Re: SYS FLASHING ON SPEEDOMETER SCREEN (mjfox)
The SYS is a signal of an error detected in the electrical system. One of the most common causes is a battery starting to go. If the CCM detects battery voltage below a set number(something like 11 volts) for a few seconds, it will falsh SYS. When you pulled the code 16, that was from the ECM. It's one of the codes for an optispark problem. Has the car been running well? Oh, yea, one other thing.. TURN OFF THE CAP LOCKS. :steering:
Old Sep 25, 2003 | 10:23 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: SYS FLASHING ON SPEEDOMETER SCREEN (Ramrod92)
Maybe not. There is a really cool procedure you can use to pull the CCM codes which are independent of the ECM codes. Code 16 there might mean low battery. Let me consult my shop manual, of course that means I have to FIND my shop manual :smash:
Old Sep 25, 2003 | 10:35 AM
Nathan Plemons
Default Re: SYS FLASHING ON SPEEDOMETER SCREEN (Nathan Plemons)
well for a couple of books they sure do grow legs. My dad was doing some work in the garage yesterday, I'll have to find out where he put them.
Old Sep 25, 2003 | 10:38 AM
bogus's Avatar
bogus
yea... I know... but I don't remember the procedure.
I am concerned... you mentioned a jump, did you jump or charge the battery? that can damage the electrical system, if not done right.
Also, the code 16 is related to the optisparks low res (opti part) signal. The lowres is related to fuel delivery and spark timing.
a failing opti can die without throwing a single code, but when they do throw one, 16 is the most common.
Old Sep 25, 2003 | 02:05 PM
Nathan Plemons
hmm.
The CCM code 16 would be ignition 3 fuse circuit open. As others have said ECM code 16 is an opti problem.
BTW if the computer picks up a code 16 on the opti it should set a service engine soon light. If it's not doing that then it may well be the fuse. I'll see if I can find out where that might be.
Could have blown something when you jump started it.
[Modified by Nathan Plemons, 1:07 PM 9/25/2003]
Old Sep 26, 2003 | 08:02 PM
87Z-ya's Avatar
87Z-ya
Nathan since you have a book and I dont, is code 13 a o2 code for driver or pass side? I also keep getting the sys flas but mine has no charging system problems?
Old Sep 26, 2003 | 08:06 PM
Nathan Plemons
Default Re: SYS FLASHING ON SPEEDOMETER SCREEN (87Z-ya)
Factory service manual says left. I believe they mean that as if you are facing forward, so that would be driver's side.
It says Left Oxygen Sensor Open
sounds like it's not even plugged up?
Old Sep 26, 2003 | 09:59 PM
ittlfly's Avatar
ittlfly
If you have installed an after market stero, that can cause the "sys" to flash also. If that's not the case, then your battery/ charging system has a problem. Just my $.02 worth.
Old Sep 27, 2003 | 05:28 AM
Atok's Avatar
Atok
sTUMPED
THANKS MIKE
What year is your car?
I disagree with what others are telling you. The SYS message has nothing to do with the electrical system, although a low battery can cause the SYS message to appear. All "SYS" means is the CCM is storing a code. You mentioned code 16, what sub-system is that? PCM? CCM? ABS/TCS? etc. When you check the codes the CCM will tell you the system.
I don't think you have anything to worry about. Once during an alignment job I ran my battery down. When I started the car the CCM logged about 6 random codes due to the low battery. Nothing was wrong with the car, the CCM just had a brain fart due to low power. Clear the codes and everything will be fine.
:cheers:
Old Sep 27, 2003 | 08:38 AM
Nathan Plemons
Default Re: SYS FLASHING ON SPEEDOMETER SCREEN (Atok)
How is a low battery not a problem with the electrical system?
CCM code 16 refers to a blown fuse. I've never heard of a hydraulic fuse, so chances are this is electrical.
The ECM code 16 means a problem with the opti and it would also set a service engine light. ABS / ASR doesn't even have a code 16.
Almost all of the CCM codes deal with either a circuit that is open or operating out of parameters. It's almost all electrical.
BTW did you know the SYS light will flash if you pull the courtesy lamps fuse? Sure it could be nothinig, and it could reset itself. Since he did have a code 16 though, what's it gonna hurt to check it out?
Old Sep 28, 2003 | 05:30 PM
87Z-ya's Avatar
87Z-ya
I figured out my sys flash today! :hurray: For a while I have had to press very hard on the buttons on my dic to toggle between features. I took the dash apart and the 5 pin connector on the back of the dic was loose. Now buttons only have to be gently pressed and sys is gone!
To SYS FLASHING ON SPEEDOMETER SCREEN
