Safe LT4 rev limit?
Old Sep 25, 2003 | 12:51 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Default Safe LT4 rev limit?
Here's the deal, I just bought a 97 LT4 Firehawk, and SLP/GM used the stock LT1 ECM tuning on these cars (~5700rev limit). The motors were balanced and blueprinted by SLP, so what should I safely be able to rev to? Also, what is the stock LT4 rev limit?
Old Sep 25, 2003 | 05:20 PM
RichS's Avatar
RichS
Default Re: Safe LT4 rev limit? (LT4Firehawk)
My LT4 is set at 6800.
Old Sep 25, 2003 | 05:30 PM
scorp508's Avatar
scorp508
.....so what should I safely be able to rev to?
Are you looking just to make noise? Bring her on over to a dyno to see where the powerband is. If it stops making power @ 5700 then why bother going higher until you do some modifications that make the higher RPM useable?
Old Sep 25, 2003 | 05:45 PM
EvanZR1's Avatar
EvanZR1
Default Re: Safe LT4 rev limit? (scorp508)
I'm trying to find out what the factory limit was set to on the LT4, and how much (if any) higher than this LT4 owners have found to be safe. I plan on dynoing it, but I'd like a starting point to work from.
Old Sep 26, 2003 | 07:31 PM
Dan Parker '96's Avatar
Dan Parker '96
6411rpm is the stock limit on the LT4 PCM (according to LT1 Edit).
I did an LT1 to LT4/Hotcam conversion along with bearings, rings, etc.
With my LT1 bottom end (plus ARP main studs) I hit 6500rpm shift points consistently without fear of failure for the past 5K miles. This has included a 100hp shot of nitrous used in the last 2K with no worries (N2O shot from 3000-6000rpm)
The LT4 has the benefit of a bit of crank work (rolled, filleted journals) and cracked cap connecting rods compared to the regular machined mating surface on the LT1 connecting rods. In '96 both the LT1 and LT4 benefitted from half keystone piston rings for reduced high rpm ring flutter.
The LT4 (and LT1 as well) are really only limited by their respective valvetrains. The bottom end (properly assembled) will withstand 6K+ revs all day long. The LT4 is good for repeated short duration runs up to the PCM limit of 7k rpms ( I wouldn't endurance race it there naturally... mostly due to the oil pan not being baffled).
Unless you road race your LT4 then I wouldn't have any reservations about banging the rev limiter on occasion.
Old Sep 28, 2003 | 06:30 PM
LT4BUD's Avatar
LT4BUD
Somehow it just doesn't make sense to me that SLP would blue print an LT4 engine that in stock Corvette form makes it maximum hp at 5800 rpm and put a rev limit of 5700 on it AFTER they blueprinted it. Not saying it isn't so since I don't know but this certainly doesn't make sense.
Answer to your question is the Corvette LT4 is redlined at 6300 and rev limiter is set at 6400.
Based on torque/hp curves I have seen for LT4's, the best performance will be obtained by shifting at redline just before the rev limiter, that is 6300.
Old Sep 28, 2003 | 09:29 PM
96GS#007's Avatar
96GS#007
Default Re: Safe LT4 rev limit? (LT4BUD)
:iagree: 6300 redline / 6400 fuel cutoff are the stock settings. On a stock engine, above 6400 you're just making noise. If you make changes (i.e. cam, etc) the LT4 valvetrain is the limiting factor and is good to 6800. I have the LT4 HOT Cam and spin mine to 6800.
Old Sep 29, 2003 | 02:15 PM
EvanZR1's Avatar
EvanZR1
I've heard several reasons for this, but the one that I give the most credence to is: They had to use the same ECM or else they would have had to go through emissions certification all over again. I can't see them doing that for roughly 130 cars (total SS and Firehawk LT4s).
Thanks to everyone for the info on redline and revlimiter. I'll be doing before and after dynos and will let everyone know the results.
Old Oct 3, 2003 | 08:43 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
I reset mine to 6800 :D :cheers:
To Safe LT4 rev limit?
