Ingition Switch
Old Sep 25, 2003 | 01:05 PM
bogus's Avatar
bogus
Default Ingition Switch
The key switch is all loose and sloppy in my column (92 coupe, 6spd).
At times, the key won't turn... it takes some work to get the key to turn to start.
Does this mean I need a new ignition? if so, replacing it is gonna be nothing short of a bitch...
Thanks!
Old Sep 25, 2003 | 07:59 PM
bogus's Avatar
bogus
Default Re: Ingition Switch (bogus)
:confused:
Old Sep 25, 2003 | 08:12 PM
ffvetteman's Avatar
ffvetteman
sounds like the key cylinder needs replacing.
Its not hard but time consuming.
Good Luck and keep us posted :thumbs:
:steering:
Old Sep 25, 2003 | 11:45 PM
bogus's Avatar
bogus
Default Re: Ingition Switch (ffvetteman)
that was my guess... time to call Chris.
thanks! :thumbs:
Old Sep 26, 2003 | 12:56 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
mine does same thing sometimes it will work everytime if you dont push key cillinder in while turning
Old Sep 26, 2003 | 07:19 AM
vetteseniorcit's Avatar
vetteseniorcit
You have nothing to lose by trying this: Give it a shot of WD-40 (directly into the keyway). I tried it on my 87 and darned if it didn't solve the problem. Won't cure the sloppiness, but my guess is, it lubricated the tumblers and perhaps cleaned out some gunk. After that, the key turned very easily.
Old Sep 26, 2003 | 09:04 AM
bogus's Avatar
bogus
Default Re: Ingition Switch (vetteseniorcit)
you're about 1/2 a-step ahead of me! I am going to try that first...
but I figured this... my 92 has 117k miles... I need to service the tilt... why not go in there once, replace the signal stalk, replace the ignition and fix the tilt... done for another 117k miles!!
To Ingition Switch
