new pistons
Old Sep 25, 2003 | 02:26 PM
devilfish's Avatar
devilfish
Default new pistons
when i install new fordge pistons must i have the complete assambly rebalanced?
Old Sep 25, 2003 | 02:52 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: new pistons (devilfish)
if you are planning on an internally balanced engine (netural flywheel and balancer) - then yes.. if your planning on an externally balanced assembly.. I dont think you will..
Old Sep 25, 2003 | 02:57 PM
Dave C. '04 Z06's Avatar
Dave C. '04 Z06
Default Re: new pistons (BluByU)
If they weigh within 3-5 grams (Each) of the old ones I wouldn't worry about it, but if not then yes.
Make sure you include the wrist pins when you weigh them, because there are different weight wrist pins. (all of them in your set should be the same, but they may not be the same weight as the ones in your car)
-Dave C.
Old Sep 25, 2003 | 03:34 PM
devilfish's Avatar
devilfish
Default Re: new pistons (Dave C. '97 Z28)
so i i just comapre the wights with the old once?
Old Sep 26, 2003 | 11:21 AM
MrJay's Avatar
MrJay
Yes just weigh the old piston and pin and then weigh the new piston and pin, if they are the same then you are ok.
Jay
To new pistons
