code 32 EGR cleaning
Old Sep 25, 2003 | 04:42 PM
BILLYD's Avatar
BILLYD
Default code 32 EGR cleaning
Anyone taken their EGR valve off to clean intake passages? Hard to believe thats my problem but its the only thing left.
thanks
Bill :confused:
Old Sep 25, 2003 | 05:10 PM
Corvette0096's Avatar
Corvette0096
Default Re: code 32 EGR cleaning (BILLYD)
All the work It take to get to the thing I would just buy a new one..
Old Sep 25, 2003 | 07:36 PM
ittlfly's Avatar
ittlfly
Default Re: code 32 EGR cleaning (Corvette0096)
You could run a can of GM's Top Cleaner through it. It might clean it up enough to keep the ECM from coding out. It's a lot easier than pulling the intake to have it tanked. Just a thought.
Old Sep 25, 2003 | 07:51 PM
loflyin's Avatar
loflyin
Default Re: code 32 EGR cleaning (ittlfly)
What makes you think EGR? Is it showing code 32? If so, have you checked the diagnostic switch? What year car?
Old Sep 26, 2003 | 08:13 AM
Unriced's Avatar
Unriced
:iagree:
I took my car to the shop ( mistake) and they missed the egr temp switch.
Mine was closed so the check engine light would come on when cold.
If you're doing this yourself watch for build up underneath the egr.
It could affect the cylinder beneath it. It did in my case so I ended up
replacing intake man gaskets and cleaned in there the best I could..
And definitely spring the 70 or so bucks for a new egr and just do it once...
I am assuming tthis is an earlier C4 BTW....
Old Sep 26, 2003 | 10:09 AM
BILLYD's Avatar
BILLYD
Default Re: code 32 EGR cleaning (Unriced)
Yes I replaced the switch but that didn't solve the problem, I can tell the egr is opening. Sorta eliminated everthing but a plugged manifold.
thanks for replies
Old Sep 26, 2003 | 10:35 AM
87SAM's Avatar
87SAM
I removed the air tube to install a new blanket by unscrewing and removing the temp sensor. When it was back together I had a code 32. I backed of the temp sensor a couple of turns and the code was gone. Sounds strange, but you may want to play with the position of the sensor, it's easy to try. :crazy:
To code 32 EGR cleaning
