will this cam work?
Old Sep 29, 2003 | 08:55 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: will this cam work? (bumpnzx3)
I haven't priced any of the CC cams lately, but if price is an issue it's hard to beat the hot cam. It works wonders with the LT1 intake and has very good street manners. It does have a fairly healthy lift though which might not work with your heads so well. You could cut it down a bit if you used it with 1.5 rockers instead of the 1.6's it's rated at.
You can buy this cam all day for $180. It's 218/228 .525/.525 112, rated with 1.6 rockers.
Old Sep 29, 2003 | 10:21 AM
Dominic Sorresso's Avatar
Dominic Sorresso
bumpnzx3,
Here's MMS number. 520.792.1156. Speak to Denny Wycoff. Very knowledgeable guy. As an example, I am using a CC Hyd Roller with a 264/270d adv. duration and a 488/495 lift. LCA is 112d. With the heads I have and the infomation I provided regarding my objectives, his calc came out to be a 266/265 with a 108LCA. Denny believes this cam should be worth an additional 25-30lbft andbump my peak another 4-700rpm. At the least, its an education in understanding valve timing events. Let us know what he says. :seeya
Old Sep 29, 2003 | 01:30 PM
bumpnzx3's Avatar
bumpnzx3
From: Edwardsville, Illinois 88 stroked s10, 92 stock 6spd
Default Re: will this cam work? (Dominic Sorresso)
i will try to give them a call sometime this afternoon.
i have a set of 24lb and 30lb injectors in the garage- which should i use? i am thinking the 30's may be a bit large. any thoughts?
Old Sep 29, 2003 | 01:43 PM
Dominic Sorresso
bumpnzx3,
The 24psi injectors will support 380hp given 100% DC. The 30psi injectors will support 480hp. So it depends on what your objectives for the motor are and what you think the heads and cam will realistically support.
Old Sep 29, 2003 | 01:46 PM
scorp508's Avatar
scorp508
Default Re: will this cam work? (vader86)
383s can handle alot more cam than 350's can.
Huh? :confused:
