C5 Brake Upgrade
Old Sep 26, 2003 | 01:05 PM
Dave-T's Avatar
Dave-T
Default C5 Brake Upgrade
I am most likely going to do a C5 brake upgrade on my 94 LT1 this winter. I realize that the C5 rotors are good, however I would like to substitute a drilled rotor for looks. What would be a good rotor to use. I would also want these rotors for the rear as well. I will not be upgrading the rear calipers so these rotors would need to be the same size as the stock rear rotors.
I am also most likely going to use the stock C5 caliper(the grey one) and not the Z06(red) caliper. What can I do to make the stock rear caliper match the front C5 caliper. I would be willing to replace the rear caliper with a grand sport caliper if that is a better match.
Old Sep 26, 2003 | 03:28 PM
bogus's Avatar
bogus
Default Re: C5 Brake Upgrade (Dave-T)
dude... check http://www.stoptech.com
if you want to stop, want it to look good, then that is the real solution...
Old Sep 27, 2003 | 06:57 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Talk to Chris May At Superior Chevy 1-800-728-8267. I believe G.M. sells a drilled rotor for the C5's, perhaps for the stock C4 rears as well, don't quote me, talk to Chris, he'll know for sure.
Old Sep 27, 2003 | 02:08 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: C5 Brake Upgrade (bogus)
And what kit is it that they offer for the C4 that fits under 17" wheels?
Old Sep 28, 2003 | 02:27 AM
Goody's Avatar
Goody
Default Re: C5 Brake Upgrade (Jeffvette)
I don't think they do. You need ZR/GS OEMs or aftermarket 17" wheels or switch out to C5 wheels.....but I might be wrong.
GM makes a durastop brand of rotor now that is rather pricey but might suit your needs. Thanks to Ed Salinas's C5 adapter I will be doing the C5 upgrade as well. I'm not willing to spend $2000+ for brakes just because I autoX, but $700 is much more manageable for me and new pads/rotors aren't going to cost $500 a set either. I realize that the C5 brakes aren't the best, but they are better then my old J55's.
To C5 Brake Upgrade
