PKE Problem
Old Sep 26, 2003 | 02:19 PM
QuikZilver's Avatar
QuikZilver
Default PKE Problem
Yesterday, I noticed that the alarm was not arming on my 93 Coupe. The transmitter unlocks the passenger door and pops the hatch. It will not lock and arm or disarm. Any ideas? The transmitter is about 1 month old. Thanks in advance.
Old Sep 26, 2003 | 03:41 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: PKE Problem (Whitvette)
It sounds like the system is disabled. Hold the door button down until you hear/see the door locks cycle. This could take a few seconds. To select which door (s) open place the key in the ignition, donot turn on, & press the door button until you have selected the sequence you want. If you have armed the system properly, when you turn the ignition "on" the passive keyless bulb will be illuminated on the lower left corner of the DIC.
Old Sep 26, 2003 | 03:44 PM
QuikZilver's Avatar
QuikZilver
Default Re: PKE Problem (lou sylvestri)
Thanks, I will give that a try when I leave work. Don't know how it became disabled...was working fine up till a couple of days ago.
Thanks again!!
:cheers:
Old Sep 30, 2003 | 10:52 AM
QuikZilver's Avatar
QuikZilver
Well, that did it!!! THANKS!!!!!
:cheers:
Old Sep 30, 2003 | 10:58 AM
Goody's Avatar
Goody
Yeah, all you do is hold the door unlock button down for two seconds and the car will cycle. It's good to do when working on the car and you get tired of the doors locking you out all the time. :banghead:
Old Sep 30, 2003 | 11:34 AM
QuikZilver's Avatar
QuikZilver
Default Re: PKE Problem (Goody)
Yeah, stupid me forgot that I turned it off when I was changing my wheels. I need to post a clipboard in the garage so I can make notes of what I am doing to disassemble, so when I am done, I can make sure I put everything back on. :crazy:
Old Oct 1, 2003 | 06:49 PM
vette64red's Avatar
vette64red
I know this is a stupid question, but what door button? I have a 94 and tried the power lock but nothing happened.
To PKE Problem
