scanning my engine, buy a scanner or software?
Old Sep 26, 2003 | 08:24 PM
LD85's Avatar
LD85
Default scanning my engine, buy a scanner or software?
Which should I do but a scanner or software to look at my engine data?
What does a good scanner cost and what brand?
Or should I just buy the Diacom software?
BTW, I am a newbie to this!
Old Sep 26, 2003 | 10:06 PM
Topless87's Avatar
Topless87
Default Re: scanning my engine, buy a scanner or software? (ld85)
If you already have a laptop computer, I'd go with the software. I see you've upgraded to the 165 ECM, so I'd use Craig Moates free software to give it a try. I've also used Datamaster and like it. If you don't have a laptop, cost will be a factor.
Old Sep 27, 2003 | 03:49 AM
LD85's Avatar
LD85
Default Re: scanning my engine, buy a scanner or software? (Topless87)
Thanks, I do have a laptop, so I can use the Craig Moats software but I need a cable I guess, yes?
Old Sep 27, 2003 | 11:35 AM
scorp508's Avatar
scorp508
Whatever you do get a Windows based software for sure for your laptop. It will help in leaps and bounds down the road. Now that I got the EASE stuff that is run right in windows I can scan/tune/burn all in one place.:yesnod:
To scanning my engine, buy a scanner or software?
