Make your 89 start quicker.
Old Sep 26, 2003 | 10:24 PM
Red88Vette's Avatar
Red88Vette
Default Make your 89 start quicker.
The 89 6E codes APYP and ARAP have a problem with not starting right away. Sometimes, it takes 2 to 4 seconds of cranking before the engine will fire. The problem seems to be some missing values in a Crank Fuel PW Multiplier vs Ref Pulse table. The original table from GM is below:
Notice that the first 8 values are 0.
;Crank Fuel PW Multiplier vs Ref Pulse
;Val = Multiplier / 0.00390625
;Mult Ref Pulse
LC38B: .db 0x00 ; 0 1
.db 0x00 ; 0 2
.db 0x00 ; 0 3
.db 0x00 ; 0 4
.db 0x00 ; 0 5
.db 0x00 ; 0 6
.db 0x00 ; 0 7
.db 0x00 ; 0 8
.db 0x80 ; .5 9
.db 0x80 ; .5 10
.db 0x40 ; .25 11
.db 0x40 ; .25 12
.db 0x40 ; .25 13
.db 0x40 ; .25 14
.db 0x40 ; .25 15
.db 0x40 ; .25 16
LC39B: .db 0x33 ; .20 17
.db 0x33 ; .20 18
.db 0x33 ; .20 19
.db 0x33 ; .20 20
.db 0x33 ; .20 21
.db 0x33 ; .20 22
.db 0x33 ; .20 23
.db 0x33 ; .20 24
I added hex value $40 in each of the first 8 positions in the table, as show below:
;Mult Ref Pulse
LC38B: .db $40 ; .25 1
.db $40 ; .25 2
.db $40 ; .25 3
.db $40 ; .25 4
.db $40 ; .25 5
.db $40 ; .25 6
.db $40 ; .25 7
.db $40 ; .25 8
.db $80 ; .5 9
.db $80 ; .5 10
.db $40 ; .25 11
.db $40 ; .25 12
.db $40 ; .25 13
.db $40 ; .25 14
.db $40 ; .25 15
.db $40 ; .25 16
LC39B: .db $33 ; .20 17
.db $33 ; .20 18
.db $33 ; .20 19
.db $33 ; .20 20
.db $33 ; .20 21
.db $33 ; .20 22
.db $33 ; .20 23
.db $33 ; .20 24
This table change has allowed the engine to fire almost immediately every time.
A little note, at first I tried a $80 value, but it caused the engine to start and then almost stall from too much fuel.
Also, the 32B code, like the ABTZ from my 88, has all the values in this table set to max.
:steering:
Old Sep 26, 2003 | 11:24 PM
scorp508's Avatar
scorp508
Default Re: Make your 89 start quicker. (Red88Vette)
Red, my $32b code only has 17 fields (0-128 in steps of 8) in the CFM vs. Ref. Pulse all set to 1.00 as you stated. I no longer have a 9th injector and dead cold startsup take upwards of 5-6 seconds of cranking. Once the car is warm it fires up on the first crank typically.
I've also go the "Crank Fuel Puse Width vs. Coolant Temp" which I have added I think 25% of the original values to the entire table without seeing much help.
Old Sep 29, 2003 | 09:15 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Make your 89 start quicker. (scorp508)
Beat you to it :D
http://forums.corvetteforum.com/zerothread?id=592525 :cheers: :cheers:
Old Sep 29, 2003 | 11:26 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
I wonder if they do that to get the oil semi-circulated before the engine fires???
:chevy
Old Sep 29, 2003 | 12:22 PM
Aaron's 87's Avatar
Aaron's 87
Default Re: Make your 89 start quicker. (IBEAM700)
My 87 starts up quicker with 89 code and cold start disconnected. A lot of manufacturers build in a startup delay now.
To Make your 89 start quicker.
