Can I still drive if....
Old Sep 27, 2003 | 04:31 AM
SOVAIN1's Avatar
SOVAIN1
Default Can I still drive if....
Can I still drive my vette without a upper alternator bracket? Its a 85. Or would that damage something?
Old Sep 27, 2003 | 08:49 AM
FX GS's Avatar
FX GS
Default Re: Can I still drive if.... (SOVAIN1)
Don't see why not as long as the alternator is still being held steady with the other bolt. I would replace as soon as possible however.
Old Sep 29, 2003 | 04:51 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Can I still drive if.... (FX GS)
I agree with FX GS, but I would replace ASAP.
No long trips?
tony
Old Sep 29, 2003 | 05:47 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Can I still drive if.... (oldace84)
:iagree: to some extent. Remember there is a lot of torque forces on that bracket. You may snap the lower one without the upper one in place. I wouldnt take the chance. :yesnod:
Old Sep 29, 2003 | 06:23 PM
dwestsr's Avatar
dwestsr
Default Re: Can I still drive if.... (Southern Comfort)
Why take the chance? the longer you run it that way the more likely the lower will break. :iagree:
Old Sep 29, 2003 | 06:42 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Mine was broken, ran for a day then replaced... noticed pressure on the serp belt... and if she breaks the the alt flies, a lot more damage you could have.
Old Sep 29, 2003 | 10:20 PM
Siveck's Avatar
Siveck
If you can't get a bracket soon enough, at least make something out of a turnbuckle and 2 eyebolts to help temporarily.
Old Jan 31, 2025 | 10:28 AM
Eliasc4's Avatar
Eliasc4
1st Gear
So I replaced the air pump in my 89 c4, and now the bracket doesnt fit. The gap between the 2 bolts is a centimeter to short. I reinstalled the air pump 3 times and im certain it isnt the air pumps positioning. I even tried connecting the bracket and then connecting the air pump but then the air pump wouldn't connect. I made shure it was the same size as the old one. Does anyone know anything about this?
To Can I still drive if....
