WEIRD O2 sensor problem...
Old Sep 27, 2003 | 06:23 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default WEIRD O2 sensor problem...
The car won't go into closed loop anymore..
I put the scanner on, and the O2 readings are stuck at .450
I unplug the O2 sensor wire, STILL stuck at .450, and NO SES light!
WTF??
Old Sep 27, 2003 | 06:29 PM
scorp508's Avatar
scorp508
Default Re: WEIRD O2 sensor problem... (CarAteMyMoney)
What was the coolant temp at startup? How long was the engine running in minutes when you saw this? Personally if I saw a static reading on the O2 in open or closed loop I'd be replacing it.
Old Sep 27, 2003 | 06:32 PM
CarAteMyMoney
Default Re: WEIRD O2 sensor problem... (scorp508)
The coolant temp read 88 or so degrees after it had been running for half an hour or so..
.. what's weird is while I have a static reading on the O2 sensor, I have that same static reading whether it's plugged in or not! :banghead:
Old Sep 27, 2003 | 07:08 PM
silver & red CE's Avatar
silver & red CE
The car won't go into closed loop anymore...WTF??
Not a bad guess, huh? It's strange the wiring harness is stuck at 450mV. I wonder if there isn't a ground offset or something. I'd check the wiring harness directly with a DVM, maybe the harness is melted and shorted to the chassis?
Eric
Old Sep 27, 2003 | 08:55 PM
VetteTech81's Avatar
VetteTech81
Default Re: WEIRD O2 sensor problem... (silver & red CE)
if I remmber correctly that is the reference voltage the ECM puts out.. so that is probably normal.. once it's in closed loop you will see the voltage fluxuate.. if not the o2 is junk.. also you should see an O2 fluxuate voltage even unplugged after the O2 is at running temp because it is a voltage generator.. but it must be HOT...
-Rick
Old Sep 27, 2003 | 10:05 PM
CarAteMyMoney
Default Re: WEIRD O2 sensor problem... (VetteTech81)
so how come i dont get a trouble code when i unplug the O2?
Old Sep 27, 2003 | 10:12 PM
Nathan Plemons's Avatar
Nathan Plemons
The O2 sensor puts generates it's own voltage.
Old Sep 27, 2003 | 10:45 PM
CarAteMyMoney
Default Re: WEIRD O2 sensor problem... (Nathan Plemons)
isnt it supposed to throw some kind of code when the O2 sensor isnt completing the circuit???
besides, even when its in open loop, the O2 sensor should send numbers back to the ECM even though its not taking them into account until it reaches closed loop
Old Sep 28, 2003 | 12:28 AM
vettek50's Avatar
vettek50
TTT
To WEIRD O2 sensor problem...
