Proper procedure for adjusting parking brake???
Old Sep 27, 2003 | 09:10 PM
Wheelman's Avatar
Wheelman
Default Proper procedure for adjusting parking brake???
My parking brake doesn't do hardly anything. This wouldn't bother me much since my car is an auto, but unfortunately my car will not pass state inspection unless it will hold the car in gear to 1000rpms. This it will not do. It can hold the weight of the car in neutral on a slight incline, but that is about all it will do. Who can help me with the procedure for this. I have both a haynes manual and chiltons and both tell different ways, niether of which make since at all to me, thanks to their crappy diagrams.
Old Sep 27, 2003 | 10:34 PM
neverendingproject's Avatar
neverendingproject
Default Re: Proper procedure for adjusting parking brake??? (Wheelman)
which type does an 89 have? seperate or integral w/ the caliper?
Old Sep 27, 2003 | 10:39 PM
Wheelman's Avatar
Wheelman
Default Re: Proper procedure for adjusting parking brake??? (neverendingproject)
integral
Old Sep 27, 2003 | 10:53 PM
neverendingproject
try pulling the parking brake lever and releasing it many times w/ the car in park. it should self adjust.. if not , you have caliper problems..
no one has used a c-clamp on your rear calipers, have they?
Old Sep 27, 2003 | 11:38 PM
Wheelman's Avatar
Wheelman
:bb
The chiltons manual says to use a c-clamp to compress the pistons back into the bore when changing pads. I have done this before. Will this mess something up? And yes i have tried the self adjusting method and it isn't working for me for some reason. The brakes themselves work fine.
Old Sep 28, 2003 | 01:05 AM
JCAIRE2's Avatar
JCAIRE2
When you pull up on the handle does it make a ratcheting noise? If not, then you need to clean the handle assembly.
It should be self-adjusting, but needs the ratcheting action to do so.
Pull the seat, pull the handle cover and stuff a bunch of rags around the assembly.
Use parts cleaner and a pick to remove all the old grease from the assembly and the gear teeth.
Once it's clean, re-lube it and reassemble the cover and seat. It should start ratcheting now.
Pull up HARD on the handle several times and it should be adjusted.
I just had to do this a couple weeks ago. :cheers:
Old Sep 28, 2003 | 07:06 PM
neverendingproject
Default Re: Proper procedure for adjusting parking brake??? (JCAIRE2)
i haven't actually looked at a rear caliper on an 89, however, every car i have ever seen w/ the integral parking brake in the caliper required screwing the piston in, not pressing... the pistons are usually 2 pieces. when you pull the brake lever it actually unscrews the outer part of the piston.. im afraid that when you pressed the pistons into the bores you likely damaged them...
to verify that yours are this type of caliper, did the pistons have 2 or 4 notches in them or were they hollow?
Old Oct 2, 2003 | 05:59 PM
Wheelman's Avatar
Wheelman
It still makes a ratcheting noise when it comes up and the light on the dash still comes on but it wont self adjust!!!! :rant:
Old Oct 2, 2003 | 11:55 PM
JCAIRE2's Avatar
JCAIRE2
Sorry, I'm out of ideas. Hopefully someone else can help you out. :thumbs:
Old Oct 3, 2003 | 11:34 AM
dwestsr's Avatar
dwestsr
If you used a c-clamp on the rear caliper with integral parking brake type, you have damaged the caliper and will have to replace them. That is the likely cause of your parking brake problem. good luck
Old Oct 3, 2003 | 11:50 AM
corvette-pilot's Avatar
corvette-pilot
Default Re: Proper procedure for adjusting parking brake??? (dwestsr)
I don't have the answer to this either but have the same issue.
The dealer did the brakes about 1.5 years ago with the previous owner.
I fail the inspection so I took the car back to the dealer that did the work.
They told me it met GM specs ?? :skep:
It held the car on an incline and it holds in drive. But it wont hold at 1200rpm.
I took this info tot he inspection station and finally got the to believe that it does what GM designed it to do so how can I make it better than design and got my sticker.
Not sure what to do this year as I will go thru the same BS ??
As a stop gap idea, several others I talked to also did this.
Go to the hardware store and get one of those cable end clamps. Clamp it over the 'common' brake cable and tighten it slightly. This will put a bend in the cable effectivly shortening it. So now the brake should apply harder and pass. You can them remove the clamp.
Sneaky but should get you by until a real solution is found??
JMO as I did not stay at a Holiday Inn Express last night :D
Old Oct 3, 2003 | 01:59 PM
brookman's Avatar
brookman
Default Re: Proper procedure for adjusting parking brake??? (corvette-pilot)
You did not damage the rear caliper. The e-brake uses a lever to press on the back of the brake pad. (The old style has a ratchet in the piston. ) The e-brakes on these cars are not very good. at 1000 rpms the car is producing a crapload of torque.
Old Oct 4, 2003 | 02:12 AM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: Proper procedure for adjusting parking brake??? (brookman)
Here's the adjustment procedure via the service manual:
http://members.rogers.com/thecorvettekid/parkbrake.PDF
Hope it helps.
Good luck.
[Modified by TheCorvetteKid, 1:15 AM 10/4/2003]
To Proper procedure for adjusting parking brake???
