roller rockers
Old Sep 30, 2003 | 01:01 AM
Bluevette85's Avatar
Bluevette85
Default Re: roller rockers (cheap vet)
I thought I read somewhere that the 85 heads would bind or rub the push rods
I had no problems on my iron head 85 with the self aligning roller rockers.
Old Sep 30, 2003 | 07:31 AM
Bluevette85
Default Re: roller rockers (69vetteracer)
An 85 has guide plates and plenty of room for regular roller rockers.
Not true. No guide plates on 85 heads.
Old Sep 30, 2003 | 06:49 PM
Bilyk's Avatar
Bilyk
so what about running 1.7 on the intake & 1.6 on the exhaust ? or 1.7 everywhere with new springs?
would this work on an 85?
Old Sep 30, 2003 | 07:06 PM
greggo's 94LT1's Avatar
greggo's 94LT1
Default Re: roller rockers (montie98)
If you're still looking for a set of 1.5 roller tips...I just took a set off of my LT1 that I'm looking to sell.
Old Sep 30, 2003 | 10:49 PM
NickC493's Avatar
NickC493
Should I have any trouble out of my 1.6rr on my 93 lt1? I just had them installed and havent driven the car. because I didn't have enough time tonight. So I was wondering if I might have to worry about anything. :steering:
Old Sep 30, 2003 | 10:55 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: roller rockers (NickC493)
Did they change the springs when they installed them? If so then you should be fine. If not you should seriously consider replacing them. LT1 springs don't have a very large margin of safety built in. When you increase the lift by going with the higher ratio rocker you are increasing the stress on the springs and getting uncomfortably close to coil bind.
There are a few people running around with 1.6 rockers on stock springs but by almost all accounts it's not a wise thing to do. It's not a matter of if they will break something but rather when.
Old Sep 30, 2003 | 11:47 PM
montie98's Avatar
montie98
Default Re: roller rockers (Nathan Plemons)
Shoot, Mabe I will try the 1.7s on my 85 and new springs.
Old Oct 1, 2003 | 09:16 AM
Bilyk's Avatar
Bilyk
^i was just thinking the same thing
Old Oct 1, 2003 | 09:59 AM
jmrl98's Avatar
jmrl98
Default Re: roller rockers (Bilyk)
I have an 85 also, and am considering the 1.6 rr install. The 1.7 may require more modification to the valve cover - I'd bet 1.6 would be just fine. :seeya
Old Oct 3, 2003 | 10:26 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: roller rockers (1990CORVETTE)
OMG. Now I'm totally confused.
Thought it was a simple bolt on HP increase. But now.
I give up.
tony
:flag
