Muffler eliminator ????
Old Sep 28, 2003 | 01:41 PM
1992LT1's Avatar
1992LT1
Default Muffler eliminator ????
Hello I plan on putting muffler eliminators on my lt1, I took them off to see if I like it without mufflers and get a little bit of popping because of loosing alot of back pressure will the muffler eliminators help? Will my 92 ecu learn the a/f ratio and get better with time? I have only put 50 miles on the car withot the mufflers!
Kurt
:steering: :chevy
Old Sep 28, 2003 | 01:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Muffler eliminator ???? (1992LT1)
You will experience the popping as long as the mufflers are off. The pipes you put in place won't help with the popping.
You will lose a little power, but not enough to notice unless you race at the track a lot and compare numbers.
Old Sep 28, 2003 | 02:00 PM
vettek50's Avatar
vettek50
try this system: http://www.madvet.com/shop?store=3.&frame=4374
OR
http://www.madvet.com/shop?store=3&frame=991
both system work equally well :thumbs:
Old Sep 28, 2003 | 02:53 PM
1992LT1's Avatar
1992LT1
Default Re: Muffler eliminator ???? (vettek50)
Thanks guys! I think I am going to put a set of power effects on the christmas list from santa to go along with the 396 I am going to put in next month! I love the loader sound but not the poppping :U
Old Sep 28, 2003 | 03:24 PM
Nathan Plemons's Avatar
Nathan Plemons
I hate to break it to you but any free flowing exhaust is going to pop and crackle when you let off of it. Some are worse than others, but they all do it to an extend. Remove the cats and the problem gets worse.
Old Sep 28, 2003 | 11:27 PM
vetteseniorcit's Avatar
vetteseniorcit
For what it's worth, I just ordered a pair of Magnaflow "straight pipe" mufflers from Corvette Central. Cost $229. I figure if I don't like them I can toss them without losing much. Interestingly enough, in the catalog they are refered to as "CC's own performance mufflers" but online they are described as Magnaflow, with LT1 tips. One thing I'm certain of is that they're gonna be noisy, but that's the way I like it.
To Muffler eliminator ????
