Dyno sheet
Sep 28, 2003 | 05:19 PM
Dyno sheet
Thanks to Village Photos.
Sep 28, 2003 | 05:22 PM
Re: Dyno sheet (Steel Blue 91)
Thats way to choppy, it should be smoother.
Tune-up time
Sep 28, 2003 | 05:24 PM
Re: Dyno sheet (vader86)
I've never seen one that choppy :nonod: I'd take Vader's advice.
Sep 28, 2003 | 05:25 PM
How new are the ignition components? Do you have an adjustable fuel pressure regulator?
Sep 28, 2003 | 05:27 PM
Re: Dyno sheet (scorp508)
That's what bothers me. Just did plugs, wires, cap and rotor last month. Haven't done the fuel filter yet.
No adj. fuel pressure regulator.
[Modified by Steel Blue 91, 5:28 PM 9/28/2003]
Sep 28, 2003 | 05:29 PM
Do you have a scanner to hook to it?
How old are the injectors?
It might not be that bad. They might not have had smoothing turned up on the dyno.
Unfortunately there's no way to tell from the printout. If they did have smoothing turned on, that's terrible. If they didn't then that's typical.
Was everybody's sheet like that or was it just yours?
Sep 28, 2003 | 05:36 PM
Vader,
I don't have a scanner available to hook up.
I haven't swaped the injectors yet.
Nathan,
It is pretty much typical of the othe ones I saw. I think I can tell where the water pump started to go south on the third pull.
Sep 28, 2003 | 07:55 PM
sorry but your dyno sheet is a little 2 small for me to see......
what are your HP and Torque numbers on the 3 runs?
Is your car stock?
auto or 6 gear?
thanks!!
Sep 28, 2003 | 07:57 PM
this mayof posted allready but.....
can't read your #'s!!! what were they on the 3 runs?
mods? tranny?
Sep 28, 2003 | 08:11 PM
Re: Dyno sheet (88BlackZ-51)
Well, I seem to be over my 5MB transfer limit on Village photo?
Anyway, it's an auto. Here's the link to the numbers:
http://forums.corvetteforum.com/zerothread?id=660137
Sep 28, 2003 | 08:47 PM
thanks!!
click on the picture
Sep 28, 2003 | 08:48 PM
Have you checked fuel pressure? What about using FP to test if the injectors are still good.
Sep 28, 2003 | 09:00 PM
Vader, Can u ehlp me on my post with my shift ****? thanks!!
you seem to have a alot of knowledge with C4's.......If you can respond or mail me at rhueson@yahoo.com i would appreciate it, thanks man!
Sep 28, 2003 | 09:11 PM
That will be next on my list of thing to do. Right now I've got to deal with the water pump issue.
