What does "SYS" mean?
Old Sep 29, 2003 | 09:01 AM
hayden489's Avatar
hayden489
2nd Gear
Default What does "SYS" mean?
I have a 93 that flashes "SYS" three times every 10 to 15 secs. This appears where the temperature is displayed, and has done so for the past year. A guy at Corvettes of Houston told me that it could poss mean that some wiring is bad or hooked up wrong. The two Chevy dealers hooked up the tech 2 and could not tell me anything. So far noone can! Has anyone else had this problem, and how was it fixed?!
Old Sep 29, 2003 | 10:31 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: What does "SYS" mean? (hayden489)
Let me start by saying welcome to the forum!
There are several things that can cause the trouble you are having, hence the reason I gave the rather vague choice for the poll. There are several different codes that your car can set, in several different systems.
You can have ECM trouble codes which are typically accompanied by a service engine soon light. You can have ABS/ASR trouble codes and you can have CCM trouble codes which usually come along with the SYS light.
The two most common CCM codes are for a low battery and for a wiring fault, usually because of an aftermarket stereo. Since you've had it for a while the battery probably isn't it or you would have had trouble by now. There is a procedure for retrieving trouble codes from the CCM. It's not terribly complicated but I don't have my book in front of me right now. You can follow this procedure to get a trouble code, then we can look into that and see what it is.
BTW my personal experience has shown that you can get a SYS light if your courtesy lights fuse is blown. If you've got an aftermarket stereo it could likely be the culprit as well.
Old Sep 29, 2003 | 10:48 AM
vvv90's Avatar
vvv90
Default Re: What does "SYS" mean? (Nathan Plemons)
:withstupid:
before you get too worked up, replace your batter if it's old. This might save you a lot of head aches. I had this problems and that's all it was.
Old Sep 29, 2003 | 11:30 AM
Bodhi's Avatar
Bodhi
Default Re: What does "SYS" mean? (vvv90)
:iagree:
I had sys flashing and it turned out that my battery was dying.
To What does "SYS" mean?
