Do 96 LT1s have a TV cable?
Old Sep 29, 2003 | 11:51 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Do 96 LT1s have a TV cable?
For some reason, I don't think so. Isn't the auto trans in the 96s controlled through the computer as well? I've got a dyno session scheduled for this Saturday and I thought I remember reading on the Forum that disconnecting the TV cable before a dyno run can sometimes screw up the trans. Of course, if I don't have one to disconnect......
Thanks!
Old Sep 29, 2003 | 12:00 PM
corvette-pilot's Avatar
corvette-pilot
Default Re: Do 96 LT1s have a TV cable? (tobijohn)
:confused: :confused:
Must be a really long cable unless you don't drive far from the house :D
Old Sep 29, 2003 | 12:42 PM
QuikZilver's Avatar
QuikZilver
Default Re: Do 96 LT1s have a TV cable? (corvette-pilot)
Nope. The last year for the TV cable was 93. In 94, Chevrolet went to the 4L60E. Shifting was done by the computer. 93, still has the TV cable.
Where are you getting your car dyno'd at? If you don't mind me asking, how much is it costing?
:cheers:
Old Sep 29, 2003 | 12:46 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Do 96 LT1s have a TV cable? (Whitvette)
Thanks, Senor Neil! Kelley Performance in Hallandale is having a Dyno Day this Sat - three pulls for $55. See my earlier thread regarding:
http://forums.corvetteforum.com/zerothread?id=660781
Old Sep 29, 2003 | 12:51 PM
QuikZilver's Avatar
QuikZilver
:mad Grrr...can't make it. I will have to remember that place. Maybe one day, I will get down there and see how mine does. It is running a lot better since I replaced the plugs and wires on the driver side on Saturday. Now, I need to figure out how to replace the coil wire.... :smash: That looks like the worst wire to replace!!
:cheers:
Old Sep 29, 2003 | 01:02 PM
tobijohn's Avatar
tobijohn
Bench Racer
Too bad. Well, good luck with that coil wire. I STILL haven't used your tip on cleaning out the front of the radiator. I bought the Gunk but then discovered how unreliable the analog coolant temp guage is - the digital was registering 205 while the analog was reading about 240 - so it turns out I didn't have a potential overheating problem, after all. Stiil, I hope to get that done before Saturday... :seeya
Old Sep 30, 2003 | 12:21 AM
Goody's Avatar
Goody
Nope. 96 doesn't get cable.....on dish stuff. :jester
Old Sep 30, 2003 | 01:18 AM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Do 96 LT1s have a TV cable? (Goody)
I was wondering why the reception is so bad. It was much better in my 88 coupe.... ;)
To Do 96 LT1s have a TV cable?
