FX3 Selective
Old Sep 30, 2003 | 12:22 PM
1990CORVETTE's Avatar
1990CORVETTE
Default FX3 Selective
Should I be able to feel a difference in the ride, when I switch it from sport to performance, or even touring?
I cant feel a difference
Old Sep 30, 2003 | 12:54 PM
Dilligas's Avatar
Dilligas
Default Re: FX3 Selective (1990CORVETTE)
On my 94 I can feel a small difference between tour and sport, but there is a noticeable difference when I go to performance.
Old Sep 30, 2003 | 12:55 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: FX3 Selective (Dilligas)
It also depends on the speed you're going between modes.
Old Sep 30, 2003 | 06:12 PM
kittmaster's Avatar
kittmaster
Default Re: FX3 Selective (onedef92)
On my 94 I can feel a small difference between tour and sport, but there is a noticeable difference when I go to performance.It also depends on the speed you're going between modes.
Any also how old the shocks are, freshly rebuilt you'll feel the difference in all 3 modes.........guaranteed
Kitt
Old Sep 30, 2003 | 06:43 PM
black bart's Avatar
black bart
I can feel the difference in mine performance is much stiffer
Old Oct 1, 2003 | 02:13 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Possibly related info. We couldn't feel a difference in our 94, and it turned out the light bulb had been removed probably because 3 of the actuators and one shock gear were bad and the 2nd previous owner wanted to 'hide' the problem. Make sure the two lights on the DIC (if yours has this) lights up when the key is first turned on. If it does, then feel each actuator (or shock for the rear) and make sure you feel and hear the actuator working when the key is first turned on without starting the car (it does a counter clockwise 90 degree rotation, then a clockwise rotation, then a 20-30 degree rotation counter-clockwise). It's pretty easy to feel it in the front and just hold the shock in the rear and you will be able to feel (and hear it). Hope this helps...
:flag
To FX3 Selective
