TPIS Mini-Ram Induction
Old Sep 30, 2003 | 04:19 PM
Don&Kelly's Avatar
Don&Kelly
Default TPIS Mini-Ram Induction
I know that this is the C4 section, but I've been told that you all could answer my question better than in the C3 section.
I currently have a GM Tuned Port Injector on my '81 and due to some modifications that I've done (cam & Heads) , it's starving for air.
I'm thinking of changing to the TPIS Mini-Ram
TPIS says "Mini-Ram Intake Manifold":
"This fabulous new one-piece casting is ideal for the serious car nut. If used as a replacement over a stock Tuned Port intake, on a mild 350ci motor, you will see a 95+ HP gain. If you build the motor on the mild side, i.e. small cam and some porting, 125+ HP is very possible. If you go on the wild side you will be able to exceed any single four barrel power numbers, all with greater driveability and economy.
Installs on existing TPI vehicles with just our Fuel Rail Kit and Level VI Prom. Use the Mini-Ram to replace and out-perform any carbureted system, just add our Wire Harness. (And the rest of the relays and sensors.) You will end up with a system that was designed by the best engineers in the world.
It has self diagnostic capabilities, will run in the closed loop, open loop, and the limp home mode. Use either a mass air sensor or as a Speed/Density system. These systems have a knock sensor to protect the engine in case you get a load of bad fuel, and an oxygen sensor that will give the computer the information it needs for the best possible overall performance, mileage, power, idle quality and starting. All electronic components have either a Delco or a Bosch part number. This means you can purchase the component parts from any GM dealer or any of the major parts store chains. The system also retains the ALDL for ease of diagnosis, and does not require any field adjustments. Let us put a system together for you.
We have been driving this manifold for over ten years. It has wonderful throttle response, delivers more torque from 2000 to 2700 RPM than a stock or modified TPI, and gives a great rush of power from 3500 RPM to 6500 RPM. "
That's a pretty big claim ...
TPIS website is:
http://www.tpis.com
Any one know anything about this setup??
Thanks for the help ...
Old Sep 30, 2003 | 04:34 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: TPIS Mini-Ram Induction (Don&Kelly)
Do a search in C4 Tech. You will find MANY discussions on the miniram
Old Sep 30, 2003 | 04:35 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Need to know more about your current setup (heads, cam specs, displacement). You have other choices to consider: Superram or Stealthram(ehich might actually fit under a C3 hood).
Old Sep 30, 2003 | 04:50 PM
Don&Kelly's Avatar
Don&Kelly
Default Re: TPIS Mini-Ram Induction (NUckINg FuTS)
NUckINg FuTS:
I have a 350 L98 Chevy engine
Cam Comp Cam Extreme energy cam - #12-268-4 - 224 intake 230 exhaust - lift 477 intake 480 exhaust - lobe 114
Dart Iron Eagle Cast Iron heads - 200cc intake port / 64cc chamber volume / 2.02/1.60 int/exh values
GM Tuned Port Injection w/ a Holly 52 mm Throttle Body
Acell - DFI Electronic Control Module
Thanks for asking ...
:seeya :cool:
Old Sep 30, 2003 | 10:57 PM
NUckINg FuTS
NUckINg FuTS:
:seeya :cool:
Your heads and cam would be an almost perfect match for a Superram setup. The flat tappet cam Lingenfelter designed for the superram specifically is as follows: Duration 224/234, Lift .465/.488 on a 112CL. I say your cam is pretty close to that. A miniram, IMO, is better suited for a 383 and higher displacement engine. Also, the cam you are using is too small for a miniram. So in conclusion go with the Superram :thumbs:
Old Sep 30, 2003 | 11:52 PM
StealDads67's Avatar
StealDads67
NUckINg FuTS:
:seeya :cool:
:iagree: What he said
To TPIS Mini-Ram Induction
