ATI PROCHARGER COMING
Old Sep 30, 2003 | 05:16 PM
Tolofou's Avatar
Tolofou
Default ATI PROCHARGER COMING
At the moment I was think what should I need after buying the ATI p600b w/intercooler kit for my 91 Vert Vett Auto..
In the Kit is what would come as followsSupercharger Head Unit
Fuel Management Unit (FMU)
Mounting Brackets, Hardware, & Hoses
By-Pass Valve Kit
High-Flow Fuel Pump
Intercooler/Aftercooler
K&N High-Flow Filter System
All that under 5G's
Any more stuff I need for a complete install on a 1991 L-98 Auto. All stock except for a few upgrades..
Thanks,Rob
Old Sep 30, 2003 | 08:27 PM
StealDads67's Avatar
StealDads67
Default Re: ATI PROCHARGER COMING (Tolofou)
Fuel Pressure Gauge (~$200)
Boost Gauge (~$60)
Gauge pods (~$30)
Dyno Time to make sure your doing ok..... (~$100 +)
Old Sep 30, 2003 | 09:06 PM
Tolofou's Avatar
Tolofou
Default Re: ATI PROCHARGER COMING (StealDads67)
Should I get these all from the same place? Superchargersonline.com or do you know a great resource for all.. And IM sure to stick with 8 psi to start with and when the motor needs a rebuild I will crank the power of 12 with a cog setup..
After the install and tune I only want to spend 5g's on the whole she-bang..
If anyone has done the L-98 Auto in a 91 then step up and let me know about hood issues and clearance problems..Also any tricks or best gear for the buck..
It was a boob job or this.. My wife looks fine ;)
Robert
Old Oct 1, 2003 | 02:26 PM
Scott94C4's Avatar
Scott94C4
"It was a boob job or this.. "
Good choice! :thumbs: I am sure that your ***** are fine! :lol:
Check out http://www.summitracing.com for the gauges.
Old Oct 1, 2003 | 02:58 PM
krivera's Avatar
krivera
i have a 1991 vette with a d-1 and i would watch the programming part...the charger will do all the work it is the tuning that is a pain. so i would put some chunk of change away for tuning and such.
To ATI PROCHARGER COMING
