This is your first post? If so WELCOME :seeya Is your C4 auto or 6spd? If it's a 6 spd go with a set of 410s. I don't know the story on automatics. There are a host of little things you can do to your LT-1 to let it run a little better, but you're right to think gears first.
Yes this is my first post. Thanks for the welcome! I have an automatic. I did do a search on rear differential, but did not find what I was looking for.
Changing your differential will have no effect whatsoever on the power the engine develops, but it will have a big impact on the perceived power by increasing the rear wheel torque. The 2.59 gears that came with most C4 autos are designed to have a favorable impact on the Corporate Average Fuel Economy (CAFE) standard, but they're terrible on acceleration. In addition to changing out the gears, consider adding a high stall torque converter and using drag radials.
:iagree: But I don't know abot the drag radials. I recently did mine but was told not to hook up with the Dana 36. does that include drag radials? I'd like to know myself.
You have to ask yourself if you just want to go faster or if you really want to make more power. Gears will give you better acceleration at the cost of top end speed and fuel economy.
Engine modifications will give you better acceleration at the cost of fuel economy. You can always change the exhaust on your car. You'd be suprised how far a little sound improvement can go towards the feeling of performance.
If you've got 2.59 gears then replacing them would certainly give you the best bang for your buck as far as accleration is concerned. If you replace the torque converter you will want to choose very carefully. Even a slightly higher stall torque converter can make the car behave pretty poorly on the street. Personally I don't like the "feel" of a loose converter. When I press the gas, even just a little bit, I want the car to move. With a loose converter you will have an RPM range where the engine just basically freewheels and doesn't do anything. :U
Oh well, that's why I drive a manual tranny. Just try to drive something with a different torque converter before you go changing that.
