Performance is sucking!! help
Old Sep 30, 2003 | 10:08 PM
vetteguy216's Avatar
vetteguy216
Default Performance is sucking!! help
I am having a couple of problems here guys. Mabey you could help.
First, when I start my car cold it tends to stumble and sometimes the RPM's get to low to the point were the engine will die.
Second, when I am going around 40mph and put the pedal all the way down the RPM's will jump to 2300 the accend at a slower rate than they should.
I think my car does need new plugs and wires and mabey a fuel filter. Is it easy to install a fuel filter.
Old Sep 30, 2003 | 10:18 PM
Vothweirdon's Avatar
Vothweirdon
Default Re: Performance is sucking!! help (vetteguy216)
Fuel filter will take a few minutes, just did mine today (exact same symptoms as your reporting) running like a champ now!
Voth
