CAT question?
Old Oct 1, 2003 | 10:23 AM
HC4-Vette's Avatar
HC4-Vette
Default CAT question?
Do CATS have to be at equal distance from the exhaust manifold? My high flow CATS are a little to big, so I was thinking about staggering them.
Also, should the Xpipe go before or after the CATS?
Old Oct 1, 2003 | 12:55 PM
bogus's Avatar
bogus
Default Re: CAT question? (HC4-Vette)
It would only effect emissions until they are at the same temp... unless you are talking many inches.... and inch or 2 should not matter.
X-pipe AFTER the cats.
Old Oct 1, 2003 | 01:27 PM
HC4-Vette's Avatar
HC4-Vette
Default Re: CAT question? (bogus)
They will probably be staggered around 14-16".
I don't really care about emissions, just performance :)
Old Oct 1, 2003 | 02:09 PM
Steel Blue 91's Avatar
Steel Blue 91
Then just dump 'em and run straight pipe to the mufflers. :D If you have to do the emissions and you have them staggered, just make sure they are both warmed up and it shouldn't be an issue.
Old Oct 1, 2003 | 07:07 PM
HC4-Vette's Avatar
HC4-Vette
Default Re: CAT question? (Steel Blue 91)
That's what I have now-- true duals straight to the mufflers. :)
It's a little to loud for an everyday driver. I will try to put my Xpipe on first to quiet things down. I want more of that 'sleeper' sound.
There's alot of dumb people out there that think
1. the louder the car, the faster it is :D
2. The top speed on a car is what the speedometer says :eek:
To CAT question?
