Value Stem Seals/O-rings
I got a set of upper O-rings & lower seals from my Chevy dealer for about $50-$60.
It might be a good idea to also replace the keepers to avoid the chance of a dropped valve.
It's not that hard but it sure is time consuming and tedious. Good luck!
:cheers:
Wish I was a rich B and could pay some other mug to do stuff like this.
Ah well - We was poor, but we was 'appy.
Don't remove the heads, and don't use air. Use a piece of rope. If your valves are really gunked up, they won't let go of the retainers. You need the pressure of the rope, against the face of the valve (held in place by the piston) to push up on the retainers. Definitely buy a magnetic pick up tool, to retrieve the retainers once they do let go.
The job's not that hard, assuming the valves and the retainers part ways.
Good luck with it.
:cheers:
I do ALL my own work, from adding fluids to zaino and EVERYTHING in beteween.
That's from A-Z. Bumper to Bumper,top to bottom.
Had a 35x40 shop built just to maintain these Vettes (and my other vehicles)
But I like to call it 'Jim's Corvette Garage'.
I do GOOD work and I CAN afford to pay someone else to do it.
In the past I always came out feeling like I had a 'screw me, I'm stupid' sign pasted to my forehead after I paid for sehx with those quick buck guys out there that didn't know peadoody about what they were doing.
So, I do whatever necessary MYSELF and when I'm finished I can say "MAN! That Job Looks Beautiful!! And, I KNOW it's perfect because I DID IT.
And FOUR: I just LOVE working on these Vettes. It gets me up and away from these computers for a little while. (software engineer)
If you want to spend MOST of your time working on your Vette, get yourself two or three of them. They're almost worse than children. Always NEEDING something. :) :yesnod: :lol: :)
Good luck with your valve seal job.. it's not that hard, just a little messy.
Oh, I'll give you a little tip on your valve adjustment after you have changed the seals:
With the engine cold, I take NEWSPAPER and put them along the edge of the head just above the exhaust. This catches any oil it'll throw out when you crank it up and do the final valve lash adjustment.
You can let it run long enough to adjust the valves before the exhaust will burn the newspaper. (It only takes a few seconds per valve to readjust them)
