Turn signal woes.....
About a week ago the left turn signal indicator came on my dash and stayed lit all the time, and did not flash when i put it on. The parking light filiament in the bulb was still ok. I replaced the bulb and now the light is off the dash and both filaments work however the left turn signal flashes at about half speed, while the right one still works just fine. Does each side have its own seperate flasher? Or is there something else to this problem I havent come across yet??
Thanks in advance
Thanks in advance
Re: Turn signal woes..... (Wheelman)
Quick question? did you change the bulb in one of the four rear lights?
if so, then maybe you put the light upside down.
I was told to make certain I put mine upside right.... :confused:
The flashers both work off the same solenoid.
The speed is governed by the impedance of the bulbs. When one goes out it stops blinking. There may be another bulb on it's way out.
There's 5 on each side.... :thumbs:
