DO Throttle Body 'AIRFOILS' make a difference?
Old Oct 3, 2003 | 02:42 AM
smacko's Avatar
smacko
Default DO Throttle Body 'AIRFOILS' make a difference?
Responses from people that HAVE them fitted only please.
Please indicate your STRONGEST response
...That's all GREAT info folks, but out of 211 viewers of this Poll thus far, only 13 people have actually bothered to click on their choice...you peole must be TERRIBLE during a census! :lol:
[Modified by smacko, 12:21 PM 10/4/2003]
Old Oct 3, 2003 | 04:00 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (smacko)
I put mine on w/ other mods at the same time and noticed the difference right away! :thumbs:
Old Oct 3, 2003 | 06:47 AM
Dark-Knight's Avatar
Dark-Knight
There are threads arround with before and after dyno results, no hp gains by adding airfoil. :nonod:
Old Oct 3, 2003 | 06:52 AM
BIG JIM 54's Avatar
BIG JIM 54
For the $50 those junk things cost, you can have the front of your plenum ported and gain 3 times what the air foil will give you, whatever that is.
BIG JIM
Old Oct 3, 2003 | 08:56 AM
QuikZilver's Avatar
QuikZilver
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (BIG JIM 54)
All it did for me is make the throttle body "mouth" more attractive. :jester
Old Oct 3, 2003 | 09:15 AM
Tom Meehan's Avatar
Tom Meehan
Absolutely a waste of money, in my opinion.
Old Oct 3, 2003 | 09:25 AM
Scoob's Avatar
Scoob
Yes they make a difference...by adding profit to the seller's bottom line.
Old Oct 3, 2003 | 10:50 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
The DO have a 'weight reduction gain' benefit
They cause your wallet to be a little lighter. That'll give you a little performance gain.
Yes I DO have one. Put it on and couldn't tell a BIT of difference.
I didn't have the instrumentation to measure and quantify the 'weight reduction gain'.
As someone else said, it sure did LOOK good. Only problem is I couldn't SEE it anymore as soon as I reinstalled the air input hose.
Old Oct 3, 2003 | 11:53 AM
corvette-pilot's Avatar
corvette-pilot
BIG JIM
3 x nothing still = nothing :jester
Old Oct 3, 2003 | 12:11 PM
Goody's Avatar
Goody
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (Whitvette)
Yeah, I just need to find some automotive grade lipstick for it now. :jester
Old Oct 3, 2003 | 12:51 PM
corvettemaster's Avatar
corvettemaster
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (corvette-pilot)
BIG JIM
:rofl: i was thinkin the same thing :lol:
Old Oct 3, 2003 | 12:58 PM
jan-erik's Avatar
jan-erik
Hi.
I think there are much misunderstanding about this.
If you put one airfoil on a stock car the ndifference is not very much, hardly recognizable.
You have to mod your engine so that the limitation for more air in to the engine is the throttlebody without airfoil. If you then install the airfoil you will gain about 11 hp as they say. Allother factors limiting the airflow in to the engine will make the airfoil difference less and less.
Old Oct 3, 2003 | 01:37 PM
BowTieBlood's Avatar
BowTieBlood
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (jan-erik)
Hi.
People have done this and still gained nothing :nonod: Do a search.
Old Oct 3, 2003 | 02:30 PM
dtorc4's Avatar
dtorc4
Hi.
But that is given that the airfoil does ANYTHING AT ALL. Does it really improve or increase airflow into the engine??? Doubt it. Even IF it does, it would be so minute that it wouldn't make a difference in ANY engine. IMHO (and proven on Horsepower TV just a few weeks ago), it does absolutely nothing.
But we all know the saying: If you THINK your mod works, then it was money well spent. :thumbs:
Old Oct 3, 2003 | 09:51 PM
Scooter 94's Avatar
Scooter 94
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (dtorc4)
I installed an airfoil and K&N air filter at the same time and I could tell a difference...just barely...or maybe it was my caffiene buzz :skep:
Old Oct 3, 2003 | 09:55 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
HousePower TV...showed no gains on thier dyno.
So, not a good change.
tony
:flag
Old Oct 3, 2003 | 10:00 PM
shotchkiss's Avatar
shotchkiss
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (oldace84)
It might not help, but I doubt it would hurt anything either, kinda like decals but at least you can see them.
To DO Throttle Body 'AIRFOILS' make a difference?
Old Oct 6, 2003 | 03:57 PM
johncazin's Avatar
johncazin
OK....
I wish I could get as much response from my fuel pressure questions as this airfoil question always does.
BIG JIM
I never got interested in playing with the fuel pressure, because the ECM will just alter the pattern anyway......when I switched to the 24lb SVO injectors, I just made sure the injectors were working around a 90% duty cycle, which the stock pressure allowed.... and ya, still sad I wasted money on that stupid foil, but at least it looks pretty.
Old Oct 13, 2003 | 08:30 AM
tuband's Avatar
tuband
Cruise-In I Veteran
I bought 3 and painted them different colors. They make great paper weights ... stuff under the red one is high priority, must do today! :skep:
Old Oct 13, 2003 | 11:58 AM
pettsir's Avatar
pettsir
Default Re: DO Throttle Body 'AIRFOILS' make a difference? (tuband)
i installed an air foil with some other intake goodies. they seemed to free up the engine in the upper rpm range around 5500-6300. before i put the mods on, K&N filter open air lid, granitelli MAF, T-body coolant bypass and relocated the IAT sensor, and air foil. the air foil i installed last and noticed the engine free up just a little. nothing huge but noticable. i now bounce off the rev limiter before the traps rather than while going through the traps. like i said nothing crazy, but noticable at the track. :steering: :auto:
