Problems with 88 security system
Old Oct 7, 2003 | 03:55 PM
Daz 88 Vette's Avatar
Daz 88 Vette
2nd Gear
Default Problems with 88 security system
Can anyone help? Have a problem with the anti theft system of my 88 C4. When the key is removed from the ignition and the door locked the security light continues to flash instead of going out, it also stays solid if the alarm is activated. The car is only used occassionally and after 3 weeks the battery is completely drained. Has anyone come across this before and if so how did you solve it? Many thanks for your help.
Old Oct 7, 2003 | 05:52 PM
HapAFcop's Avatar
HapAFcop
Default Re: Problems with 88 security system (Daz 88 Vette)
Do a search for "VATS" and you'll probably find something.
I don't know much about it, but it sounds like the VATS module might be causing it. I think its a little black box plugged in somewhere under the dash. Your key and ignition switch are also tied into the system, however I doubt they are the culprits. If that was the case the car more than likely wouldn't start.
Good luck!
Old Oct 9, 2003 | 12:15 PM
Daz 88 Vette
2nd Gear
Default Re: Problems with 88 security system (HapAFcop)
Thanks for the advice will give it a try and see what I can come up with.
Old Oct 9, 2003 | 12:57 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Darren,
I live just up the A1 near St. Ives! Send me an email, we can get together this weekend and I'll sort you out.
[Modified by Ray Quayle, 4:58 PM 10/9/2003]
To Problems with 88 security system
