Seating Injectors...
Old Oct 7, 2003 | 07:33 PM
Twanster2000's Avatar
Twanster2000
Default Seating Injectors...
Anyone have any ideas on how seat the front right 2 injectors without taking the intake runner off. I have the plenum off now, and those injectors seem to be leaking at the base. I don't want to take everything apart because well you probably know... I've already done that once.
Also, how do you remove a stripped out torx bolt. The shop that did some work on it last didn't leave me any thing to work with.
Stock 86 with new 24# Accel GM injectors.
Old Oct 7, 2003 | 08:39 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: Seating Injectors... (Twanster2000)
Injectors seal with O rings. You have to pull the injector and replace the O ring.
On the screw; sometimes you can use a Dremel and cut a slot across the head and use a regular screw driver if it isn't too tight.
Old Oct 7, 2003 | 09:10 PM
Twanster2000
Default Re: Seating Injectors... (LaVidaLoca)
The new injectors came with new orings...
[Modified by Twanster2000, 2:10 AM 10/8/2003]
Old Oct 7, 2003 | 09:40 PM
Switch's Avatar
Switch
If you suspect that somethings not right, better take it back apart and remove the o-rings and look for nicks or cuts. Always put some lube on them before installing if keeps them from getting damaged.
Gordon
Old Oct 8, 2003 | 01:30 AM
Twanster2000
Default Re: Seating Injectors... (Switch)
Yeah... I took it apart... And somehow, someway I put it back together properly... No more leak! Thanks
To Seating Injectors...
