C4 drivetrain question?
Old Oct 7, 2003 | 07:43 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default C4 drivetrain question?
I'm gonna put a 550HP SBC in my 89 C4 and was wondering if the rest of the drivetrain will be upto the task. I've got a Art Carr 700R4 ( I've never used a 700R4 behind this much power and although Art Carr claims it will last I'm kinda skeptical) also I have Denny's driveshaft and halfshafts with a otherwise stock D44's with 3.45:1's. Anyone see a weak link? I'll be shifting at around 6500 top's and mostly on DRadials. I'm considering the much stronger Th400 along with a 2.56:1 rear gear which would actually give me 2 speeds for the quarter and third would act like an OD gear, but I'm concerned about how much this would slow the car down versus the 700R4/3.45:1 combo. Any suggestions from 700R4 owners? :confused:
Old Oct 8, 2003 | 02:03 AM
gcrouse's Avatar
gcrouse
Default Re: C4 drivetrain question? (JUAN J SANCHEZ)
Sounds good. Make sure you have bulletproof U-joints everywhere (and no grease fittings). Also check your rear wheel bearings. While you're at it, has the diff oil ever been changed? I like the Redline shock-proof 90/140 wt for puttin that kind of power to the ground. One more idea- the ZFdoc drive beam reinforcements will help keep things aligned under heavy torque.
Old Oct 8, 2003 | 06:23 AM
JUAN J SANCHEZ
Default Re: C4 drivetrain question? (gcrouse)
Thanks! I'll look into the ZFdoc beam supports. I will be putting new rear wheel bearings and new fluid also. The RWHP will be around 440.Thanks!
Old Oct 8, 2003 | 07:12 AM
scorp508's Avatar
scorp508
Your weak link will be your outter spindles in the back.
Old Oct 8, 2003 | 09:46 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I would not worry about the outer spindles with Drag Radials and an automatic. Usually they are a problem with slicks, high rpm launches, and stick shifts. I would say the weak link is Art Carr, or at least his trannies.
Old Oct 8, 2003 | 10:34 AM
scorp508's Avatar
scorp508
Default Re: C4 drivetrain question? (Vette92)
Good point on the auto & spindles, Chris. :yesnod:
Old Oct 8, 2003 | 01:38 PM
jburnett's Avatar
jburnett
Default Re: C4 drivetrain question? (scorp508)
Cryo EVERYTHING...Especially the spindles... Ya'll knew I was gonna say that didn't ya???
:D
-Jeb
Old Oct 8, 2003 | 04:12 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: C4 drivetrain question? (jburnett)
I am a firm believer in cryoed parts. I dump the clutch at 5500-6000 rpm with slicks, and run low 1.5 60 ft times and nothing breaks. It amazes me how much abuse it will take.
Old Oct 8, 2003 | 07:14 PM
JUAN J SANCHEZ
Default Re: C4 drivetrain question? (tpi 421 vette)
I'm gonna send you (jburnett) my valve springs and the I don't know what they call 'em splined shaft that ties the diff to the half shafts, why not the spindles? What is it exactly I have to have cryoed?
Old Oct 8, 2003 | 09:34 PM
tkrussell's Avatar
tkrussell
Who's your favorite vendor for cryo-treatment? Is this something that any local cryo shop can do? Are there any "secrets"?
Old Oct 8, 2003 | 10:09 PM
Ramrod92's Avatar
Ramrod92
Default Re: C4 drivetrain question? (tkrussell)
Thomas, get in touch with jburnett (Jeb), he'll let you know exactly what's needed and he is not to far from you (Little Rock). badvette@prodigy.net
Old Oct 9, 2003 | 01:27 AM
SoCal C5's Avatar
SoCal C5
FYI the real Art Carr has come out of retirement and can be found at California Performance Transmission
(877)Art-Carr, (877) 278-2277
The guy in Texas started using Art's name while Art was still retired. I do not know much about the guy in Texas but you have to wonder about someone that is standing on someone else's reputation.
To C4 drivetrain question?
