Crappy feeling clutch help!
Old Oct 7, 2003 | 08:39 PM
Storz's Avatar
Storz
Default Crappy feeling clutch help!
Its not slipping, and the fluid level is fine, the first half of the pedal throw (floor-up) is sticky second half the pedal is mushey??? I am going to change the fluid this weekend, you think it could be something stuck or messed up with either hte slave or master cylinder??
Old Oct 7, 2003 | 09:26 PM
bogus's Avatar
bogus
Default Re: Crappy feeling clutch help! (Storz)
year?
could be a bad master/slave....
Old Oct 7, 2003 | 09:32 PM
vmi_vette's Avatar
vmi_vette
Default Re: Crappy feeling clutch help! (bogus)
:iagree:
Check ZFDoc's website - he has a section on clutchs. Sounds like you might have a bad slave/master cylinder. My pedal is starting to feel mushy so I am replacing both this weekend.
Old Oct 7, 2003 | 10:54 PM
JADVette94's Avatar
JADVette94
Default Re: Crappy feeling clutch help! (vmi_vette)
:iagree:
Everyone reccomends replacing both at the same time.
BTW, vmi_vette, did you go to Virginia Military Institute (VMI)?
Old Oct 8, 2003 | 02:15 PM
Storz's Avatar
Storz
Has anyone had any luck with the rebuild kits for the master/slave cylinders?? A link for that ZF Doc site would be cool if anyone has it handy
[Modified by Storz, 7:16 PM 10/8/2003]
Old Oct 8, 2003 | 03:54 PM
STL94LT1's Avatar
STL94LT1
zfdoc.com
To Crappy feeling clutch help!
