Question About 6-Way Power Seat
Old Oct 8, 2003 | 10:33 PM
RayJay's Avatar
RayJay
Default Question About 6-Way Power Seat
My driver's seat is a 6-way power seat. It will move forward and backward and up & down but it won't tilt. Do I need to replace a motor or the seat track (stripped gears)?
How difficult is it to replace either one of these items? Can a person with only moderate mechanical skill do this? :confused:
Old Oct 8, 2003 | 10:36 PM
Siveck's Avatar
Siveck
Default Re: Question About 6-Way Power Seat (RayJay)
If the track actually moves up and down, then it should also tilt. I wonder if maybe the switch assembly is bad rather than the track.
Old Oct 8, 2003 | 10:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 Vette getting the seats out is a piece of cake.
From there it should be rather simple to service the tilt motor or controls.
Old Oct 8, 2003 | 10:47 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I don't think any of the later C4 seats came with power tilt. Both my '93 and '95 have a tab located on the edge that you pull to tilt.
I believe 1990 and earlier have power tilt, but 1991 and up they don't.
Old Oct 8, 2003 | 10:51 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Question About 6-Way Power Seat (Mr Mojo)
I think he is talking about the tilt function of the base, not the tilt of the seat back itself. If you hold the power switch a certain way it adjusts either the front up or down by itself or the rear up and down by itself.
Old Oct 8, 2003 | 10:52 PM
1990CORVETTE's Avatar
1990CORVETTE
My 90 dont tilt
Old Oct 8, 2003 | 10:55 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Question About 6-Way Power Seat (Jeffvette)
Gotcha, in that case, are you "twisting" the switch? That's how it works on mine? Although I must say I wish the back part of teh lower seat would go lower.
To Question About 6-Way Power Seat
