Alum flywheel and knock sensor?????
Old Oct 9, 2003 | 02:22 PM
jerkyboy's Avatar
jerkyboy
Default Alum flywheel and knock sensor?????
Got the car on the dyno and trying to figure out why the car runs ok at cruise, but when you go to WOT, the fuel and timing fall flat. I am being told that the knock sensor is being triggered by the knocking around of my tranny with the single mass alum flywheel and retarding timing?? Is this BS????
Old Oct 9, 2003 | 02:47 PM
ZylaRace's Avatar
ZylaRace
Default Re: Alum flywheel and knock sensor????? (jerkyboy)
Do you have access to a Scanner? Hook it up and take a look.
Old Oct 9, 2003 | 02:54 PM
jerkyboy's Avatar
jerkyboy
The dyno shop ( I'm at work wringing my hands) said that the scanner showed the knock sensor activating. No knock in engine though. The only noise is coming from the bellhousing area. Can that tranny rattle set off that sensor??? They are pulling the trans out know to make sure the Centerforce did not come apart
Old Oct 9, 2003 | 03:00 PM
Strick's Avatar
Strick
Oh Boy, keep us posted. I'm looking at a Centerforce clutch, too. What's wrong with the OEM dual mass? Just too heavy?
Old Oct 9, 2003 | 03:01 PM
DF's Avatar
DF
Anything that makes the right (or wrong ;) ) frequency can be picked up by the sensor. It can be a huge pain hunting down the cause of it. :crazy:
Old Oct 9, 2003 | 03:08 PM
jerkyboy's Avatar
jerkyboy
Default Re: Alum flywheel and knock sensor????? (DF)
I figured saving 50lbs of rotating mass would help the engine rev quicker. That it did but the rattling was god awful but I was willing to put up with it. After a few dyno runs last night, there was even more noise coming from the area with a load on it. The shop shut it down and thought it might be a good idea to pull the tranny. Hate to waste a tranny so I told them to go ahead. I am awaiting results impatiently. I am dynoing 100+ hp shy of where I need to be. These poor guys have been going nuts trying to find out why the car turns lean under load. I still have the dual mass. I will take it to them and have them reface it if I have to.
Old Oct 9, 2003 | 03:22 PM
comp94's Avatar
comp94
try checking the tps it should be reading 4.5 to 4.7 volts at WOT. i think that they are adjustable on the tune port motors
also dont to forget to check the MAF sensor i know the ones that came on the grand nationals were junk.
good luck
[Modified by comp94, 8:32 PM 10/9/2003]
Old Oct 9, 2003 | 03:40 PM
ZylaRace's Avatar
ZylaRace
Default Re: Alum flywheel and knock sensor????? (comp94)
You don't have to hear a knock for it to trigger the spark retard function,... But if you hear it (knock) it is more than likely triggering the retard.
Easy way to test it,... disconnect the knock sensor wire, and watch the scanner.
Old Oct 9, 2003 | 03:50 PM
Strick's Avatar
Strick
Rumor has it that you shouldn't resurface a dual mass flywheel. Just clean it up. If the grooves are too bad, or burnt, get another one. I know, very expensive.
Old Oct 9, 2003 | 04:00 PM
jerkyboy's Avatar
jerkyboy
Default Re: Alum flywheel and knock sensor????? (Strick)
It makes me want to :U to think I wasted all that $$ on an aluminum flywheel and have to now buy a new one. Man, the cost of goin' fast!!!
Still waitin' to hear from the shop 4:00 pm now (is that clock working??)
Old Oct 9, 2003 | 06:12 PM
BAM92's Avatar
BAM92
Your the first I have heard of having a lt weight flywheel trigger the knock sensor. Has to be something else.
Old Oct 9, 2003 | 06:47 PM
ncsugreywolf's Avatar
ncsugreywolf
Default Re: Alum flywheel and knock sensor????? (BAM92)
I just replaced my clutch and Dual Mass Flywheel in my 95 with a GM OE Clutch and the Fidanza Single. BOY WHAT A RACKET that gearbox is making. I can seriously tell the difference in the rev though...much quicker overall.
The clatter just maybe too much for me to take though.
Joal
[Modified by ncsugreywolf, 6:47 PM 10/9/2003]
Old Oct 9, 2003 | 06:51 PM
jerkyboy's Avatar
jerkyboy
Default Re: Alum flywheel and knock sensor????? (ncsugreywolf)
well, here is the latest. As of 6pm EST, apparently my brand new throw out bearing and pilot bearing are completely shot. Flywheel and clutch look OK. Now, do I take my old dual mass flywheel to them to install or stick with the Aluminum. Decisions Decisions. I just want to know how those bearings can be out in less than 2k miles???
Old Oct 9, 2003 | 09:56 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I have run aluminum flywheels on several vehicles.
IHHO it would be better to stick with the aluminum flywheel.
Old Oct 9, 2003 | 11:14 PM
superlund's Avatar
superlund
Default Re: Alum flywheel and knock sensor????? (VetNutJim)
I have the Fidanza & LT4 knock module in the PCM, no problems with the knock sensors picking up false knock from the ZF / Fidanza at all... I scan constantly with Datamaster.
To Alum flywheel and knock sensor?????
