erratic needle movement when testing fuel pressure
Old Oct 9, 2003 | 04:55 PM
tpivette's Avatar
tpivette
Default erratic needle movement when testing fuel pressure
i recently removed my plenum, runners, fuel rail, and injectors so i could port the TPI intake. while the injectors were out i replaced the orings. i assembled everything and started it up and it ran fine... no audible or visible leaks (fuel or vaccum). however, now when i test my FP, the needle vibrates back and forth, not giving me an accurate reading. my dragstrip performance has also suffered a bit (lost about a tenth and almost 2 mph). before the TPI work, this never happened, and the FP guage needle was always dead on with no movement. what do you think has caused this?
Old Oct 9, 2003 | 05:18 PM
Flame Red's Avatar
Flame Red
Default Re: erratic needle movement when testing fuel pressure (tpivette)
just a shot in the dark:
Did you remember to hook up the vacum line to the fuel pressure regulator?
Old Oct 9, 2003 | 05:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It sounds like a fuel leak or, if connected, a vacuum leak.
Old Oct 9, 2003 | 06:00 PM
BAM92's Avatar
BAM92
Default Re: erratic needle movement when testing fuel pressure (65Z01)
How long were you down for. Any chance bad gas?
Old Oct 9, 2003 | 06:20 PM
tpivette's Avatar
tpivette
Default Re: erratic needle movement when testing fuel pressure (BAM92)
the car was down for about a week. i figured i might have a fuel leak, but i dont smell gas anywhere under the hood. guess ill have to look again
Old Oct 9, 2003 | 07:45 PM
JackDidley's Avatar
JackDidley
What AFPR do you have ? When I put a JET AFPR on my 86 it did the same thing. I think the adjuster bolt is skinny and moves around. Got rid of it.
Old Oct 9, 2003 | 08:14 PM
tpivette's Avatar
tpivette
Default Re: erratic needle movement when testing fuel pressure (Spankyellow)
i have the Holley one. its got a thumbwheel to adjust pressure, not a bolt. the car has never done this before i disassembled the intake. all testing has been with the vac hose disconnected to view fuel pressure at WOT
Old Oct 9, 2003 | 08:42 PM
65Z01's Avatar
65Z01
In that case it sounds like a gas leak somewhere.
Check around the AFPR, front of the fuel rail and check the fuel pressure gauge for leakage. Also verify the gauge is tightly screwed onto the Schraeder.
To erratic needle movement when testing fuel pressure
