crate engines
Old Oct 9, 2003 | 11:23 PM
jimshearer's Avatar
jimshearer
5th Gear
Default crate engines
Where can i find crate 350 engines for my 91 vette,all i can find on my computer are earlier engine replacements. Stock or high peformance?
Old Oct 9, 2003 | 11:30 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: crate engines (jimshearer)
You are sure to find something here http://www.sdpc2000.com/cart.asp?act...start&catid=63
If you want a L98, you can try Contemporary Corvette for a used one. 1-800-367-8388
Old Oct 10, 2003 | 12:09 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
Default Re: crate engines (Mr Mojo)
Hi Mojo.
I'm looking at doing that this winter (the TPI one http://www.sdpc2000.com/cart.asp?act...=1577&pid=9009 ). Do you know anybody that has bought from them?
[Modified by Fozzy_Bear, 12:10 AM 10/10/2003]
Old Oct 10, 2003 | 05:22 AM
pablocruise's Avatar
pablocruise
What's wrong with the current one?
The block would be a commodity. roller, 1 piece rear seal. 4 bolt mains.
Many of us can tell ya where not to get an engine!
Old Oct 10, 2003 | 09:02 AM
vader86's Avatar
vader86
I dont know if anyone sells a crate L98
The L98 is just a regular Small-Block Chevy, same one they used in the muscle car era, with just a different intake manifold on top. Any of those will work.
Old Oct 10, 2003 | 07:57 PM
BIG K's Avatar
BIG K
Have you thought about yanking out your engine and sending it in to Jaspers?
They went through my L98 complete with heads shipped both ways for about $2K give or take. I also have a 3 yr/75K mile warrentty.
Just a thought.
Good Luck
Old Oct 11, 2003 | 02:24 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: crate engines (Fozzy_Bear)
I used to live in Lubbock, and I did a whole lot of shopping at Scoggin-Dickey. They're awesome to deal with and on the rare occasion someone had problems, they were very good to deal with in getting it straightened out. When I need a new motor, there going to be the ones I go through.
Chris
Old Oct 11, 2003 | 03:02 PM
ToniH's Avatar
ToniH
ZZ4 is a direct replacement. Just use your old TPI setup, distributor and some other minor bits on it and it will install and work just fine. It even gives you a bit more power than the stock motor. If you want to get some more power add GM Hot Cam and 1.6 roller rockers + port your intake.
Links to the products: http://tinyurl.com/qkut and http://tinyurl.com/qkvf
Greets,
ToniH
To crate engines
