'89 HEADLIGHTS STICK!!
Old Oct 10, 2003 | 12:56 AM
joseph p's Avatar
joseph p
Default '89 HEADLIGHTS STICK!!
My '89 coupe has now gotten to the point where I can't get the driver's headlight to come up fully unless I turn it on and off about six times. If I touch it when it sticks, it drops down and doesn't go any further unless I shut them off and turn them on again.I hear the motor spin but it still doesn't open.
Anybody have this problem and know a solution. Is it gearing??
Thank you.
Old Oct 10, 2003 | 01:02 AM
BAM92's Avatar
BAM92
Default Re: '89 HEADLIGHTS STICK!! (joseph p)
You need the 3 little bushings that cost around 5 dollars from the corvette magazines. Do both headlights while your at it as the other one will go soon. Easy repair. My 89 and 92 both did it.
Old Oct 10, 2003 | 09:22 AM
joseph p's Avatar
joseph p
Default Re: '89 HEADLIGHTS STICK!! (BAM92)
Wow, almost sounds TOO easy. I thought it might be gears. Thanks for the help, I'll order them today.
Old Oct 10, 2003 | 09:46 AM
chucks88's Avatar
chucks88
I had the same syptom on my passenger headlight. I bought the bushings from Eckler and all is well. If took me 2 hours on the first light, 45 minutes on the second. Do a search and read up on the topic in the C4 tech tip section. That's where I picked up the instructions on my headlight mod. You may even pick up a couple tenths or two down the 1/4 mile. :p:
To '89 HEADLIGHTS STICK!!
