Cluster Lights
Old Oct 11, 2003 | 10:42 AM
djbraxton's Avatar
djbraxton
Default Cluster Lights
Where can I find some replacement bulbs for my 88 cluster. I have read that 891's draw to much current and will damage the printed wiring board. Driving at night is no fun...
Thanks,
Old Oct 11, 2003 | 11:55 AM
1Patriot's Avatar
1Patriot
Default Re: Cluster Lights (djbraxton)
Pick them up at Wal-marts; xheaper than auto parts.
Old Oct 11, 2003 | 12:26 PM
JCAIRE2's Avatar
JCAIRE2
They are bulb #882, walmart or Napa should have them. Might have to order them through Napa, as they don't stock many of them at one time. I'm not aware of any bulbs that you can swap for part #882.
Old Oct 11, 2003 | 03:16 PM
SBNova's Avatar
SBNova
I posted this same topic just last week. I had a very hard time finding ANYONE who stocks these. They are 882's, 12v and something like 4 watt. They are also about $10 each. I did find that for a temporary or even permanent fix you can install the whole little "socket" (the little pastic 1/4 twist thingy) and incandescent bulb from a 90 Camaro cluster and it will fit and work fine. They are alot cheaper and seemed to have comparable brightness. I did not however compare them in direct sunlight.
Old Oct 11, 2003 | 11:26 PM
djbraxton's Avatar
djbraxton
Default Re: Cluster Lights (SBNova)
Thanks Fellas,
I'm going to have to order them, seems like nobody stock them as posted. :confused:
Old Oct 12, 2003 | 08:44 PM
HG's Avatar
HG
I found a NAPA store near me that had the 882 bulb and socket for $7. Dealer wanted $22 for the same thing. Try this link
http://www.napaonline.com/cgi-bin/nc...0&prmenbr=5806
Old Oct 14, 2003 | 04:06 PM
djbraxton's Avatar
djbraxton
Default Re: Cluster Lights (HG)
Went to my local NAPA store and they had 4 in stock.
Thanks for your help.
To Cluster Lights
