ABS questions
Old Oct 12, 2003 | 09:34 AM
subman's Avatar
subman
Default ABS questions
Ran 1st autox this (see post in general) and ran into two problems, first being brakes. A week ago , I replaced all the brake fluid using MiteyVac. Fronts pulled fluid easily but the rears took forever. Build up vacuum, go have a smoke and a beer, mow the yard and then I would have a full canister. When I ran yesterday, hit the binders and a bump, the brake pedal would feel firm then mushy then firm then mushy then firm and the ABS light would show on the dash. Could I have a bad ABS or is there a check valve going to the rears that could be bad or need adjusting? The rears are working 'cause there is the usual brake dust and normal rear wear. Or is this whole thing normal and I'm being paranoid.
Thanks for the help.
Subman
