Brakes locked on, help.
Old Oct 13, 2003 | 08:18 AM
94 Red Roadster's Avatar
94 Red Roadster
Default Brakes locked on, help.
While out cruising this weekend my brakes partially locked on. From a standing start it feels like the emergency brake is halfway on. Doesn"t seem to be a problem at higher speeds. The problem definitely is most noticable when pulling away from a standing start. I could smell the pads after a few minutes so I shut it down. The emergency brake is off and I also turned off ASR with no effect. What do you think? Is it something I can fix myself or do I have to take it to the shop?
Old Oct 13, 2003 | 08:27 AM
87NassauBlue's Avatar
87NassauBlue
Default Re: Brakes locked on, help. (94 Red Roadster)
That depends on how good of a mechanic you are. First I would jack up the car to see if the brakes are really hanging up. Remember, you have a limited slip rearend and you will need to get both back wheels up and put it in newtral to check the rear. If it's the back, you could have a cable problem or a hydrolic problem. Do you normally use your emergency brake and did you use it just before the problem started? If you can feel the drag and smell your brakes maybe they are dragging. If you just smell pads it may be just hard driving.
Old Oct 13, 2003 | 02:23 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Could be the light is off but pads are still engaged ?
Old Oct 13, 2003 | 05:47 PM
HWoods's Avatar
HWoods
Default Re: Brakes locked on, help. (edsalinas)
the interior tubing on your brake line (the rubber lines going to the calipers) could have collapsed internally causing the brakes to drag
Old Oct 13, 2003 | 06:24 PM
1MoorTym's Avatar
1MoorTym
Could have a frozen caliper. Jack the car and see if its one wheel or more and then go from there.
To Brakes locked on, help.
