While maintaining the stock programming and stock driveability, what modifications can be made to an L98 with speed density fuel injection? I understand that the programming does not tolerate many modifications.
Since the ECM uses manifold pressure to calculate mass air flow, you can mod your engine and use an AFPR for tuning so long as you don't go too radical with the cam.
