Congrats on the purchase..
I would recommend
Bosch platinum plugs
Accel 8 mm wires,, (They look great also)
Accel Cap and rotor
K&N Oil filter
K&N Air filter
Royal purple fluids,, OIL, Tranny and rear end
Bosch PCV vlave
I am not sure if I missed anything!!!!!!!!!
For a tuneup I'll list what I'd do if I didn't know the history of the car even though I know others have. :)
Air Filter
Fuel Filter
Spark Plugs
Plug Wires
Distributor Cap & Rotor
PCV Valve
Oil
Oil Filter
Power Steering Fluid
Differential Fluid
Transmission Fluid
I might leave the HEI coil alone for now if it shows no signs of failing. The L98 only really makes power to 4200 RPM and the OEM coils will go for what seems like forever at those low RPMs.
When you pull the oil cap off take a look inside the valve cover. If things like nice and clean with just sort of a golden/bronze shine on things then the engien has been maintained well. If you see black sludge built up then somebody didn't care for your baby. :)
