Miniram Coolant routing question
Old Oct 14, 2003 | 11:07 PM
ZD1's Avatar
ZD1
Default Miniram Coolant routing question
What did you guys do with the extra heater(?) coolant hose that was deleted from the rear of the miniram?
Old Oct 14, 2003 | 11:09 PM
69vetteracer's Avatar
69vetteracer
Default Re: Miniram Coolant routing question (ZD1)
Block it off. It was only used to let air bubbles escape from the rear of the block. :chevy
Old Oct 14, 2003 | 11:27 PM
ZD1's Avatar
ZD1
Default Re: Miniram Coolant routing question (69vetteracer)
How?
Cut the tubing? What do I do with "T" block?
Old Oct 15, 2003 | 02:55 PM
-=Jeff=-'s Avatar
-=Jeff=-
How?
I took the tube off the hose and Use a bolt and clamp to plue the hole, I have since just replaced the heater lines and it is not an issue anymore
To Miniram Coolant routing question
