How do you get the headlight to turn manually?
Old Oct 15, 2003 | 09:37 PM
vader86's Avatar
vader86
Default How do you get the headlight to turn manually?
For some reason one of the screws on the side of the housing made its way out and now one headlight wont swivel into place, how do you get them to turn by hand or turn enough where i can get a screwdriver on it.
This happened once before a couple years ago, the screw on the other headlight backed out and decided to take a chip out of the hood, and i cant remember how i fixed it.
Can i put something on the screw threads so this sumbitch never backs out again? like the kiss of death?
Old Oct 15, 2003 | 09:43 PM
JackDidley's Avatar
JackDidley
Default Re: How do you get the headlight to turn manually? (vader86)
Unplug the motor first. Very important. Turn the grey **** on the motor.IT should work
Old Oct 16, 2003 | 07:15 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: How do you get the headlight to turn manually? (Spankyellow)
Unplug the motor first. Very important...snip...
I have never heard that! But?
As to something to keep it tight, try a little blue loctitie. I have also successfully used the white teflon tape for pipe fittings...that works well on rearview mirror screws, I forget how long the headlight screw is that you sre referring to.
Maybe above poster is suggesting you return the headlight to it's full position where it was before you used the manual ****, before you try to operate electrically. I'm not sure that is necessary either, but might be a good idea
:seeya
:steering:
Old Oct 16, 2003 | 07:28 PM
JasonL's Avatar
JasonL
Default Re: How do you get the headlight to turn manually? (jackdaroofer)
Never heard of unplugging the motor first either, but it can't hurt.
Anyways just turn the black **** a million times to open them manually.
As for what to use on the screws, IMHO blue loctite might be a bit much for those phillips(?) screws... you could use a bit of teflon threadsealer.
(Edit: I ought to read before posting :D )
[Modified by JasonL, 4:29 PM 10/16/2003]
Old Oct 16, 2003 | 07:46 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: How do you get the headlight to turn manually? (JasonL)
:D
I am guilty of the same thing a million times over
:D :D :seeya
Old Oct 16, 2003 | 08:59 PM
JackDidley's Avatar
JackDidley
Pre 88s you really do have to unplug to open manually. :rolleyes:
Old Oct 17, 2003 | 06:08 PM
vader86's Avatar
vader86
I unplugged it, but i see no **** to turn anywhere? It will budge when i try to move it by hand but only in the normal motion.
I need to rotate it the OTHER way, opposite to the way it usually spins. The screw is coming out at the rear of the light and is out far enough that it wont let the light rotate around.
Old Oct 17, 2003 | 07:00 PM
JackDidley's Avatar
JackDidley
Vader the **** is at the bottom of the motor. Should be gray. If all else fails its easier to remove the whole assembly than it looks.
Old Oct 17, 2003 | 07:41 PM
vader86's Avatar
vader86
Well I'll have to pull the whole thing, it wont swivel in the opposite way, the stop prevents it.
:nonod: :banghead:
To How do you get the headlight to turn manually?
