C5 Brake Conversion Question
:cheers:
Matt
:cheers:
C3000 EM BRIMBO BIG BRAKE 13.5" PKG (84-96)
For the ultimate in stopping power, Brembo sets the stage for best quality and performance. Brembo brakes are used on Indy cars, F40 Ferrari's and most Porsches. This kit includes 2) Rotors and Hats, 2) Calipers, 2) Billet Alum. Adaptors, 2) Stainless Steel, Brake Lines and one set of Brake Pads. Inquire about rear Brembo Brake Package
$ 2295.95
or
C3060 C4-TO-C5 BRAKE UPGRADE
EM has designed a package that mounts C5 brakes to the front of 1984-1996 C4 Corvettes. The C5 braking delivers unmatched performance by offering large, heavy duty calipers and extra thick rotors. This combination creates a better friction surface to handle more heat without warping or cracking the rotors. This brake package requires 17" wheels.
$ 895.00 ** APPLICATION: C4 / 88-96
C3065 C4-TO-C5 BRAKE UPGRADE
$ 1095.00 ** APPLICATION: C4 / 84-87
http://www.exoticmuscle.com/webpage....&CATSEL=BRAKES
**i guess if you buy the kits it comes with everything you need**
[Modified by Soulja_350, 1:15 AM 10/17/2003]
I see you have already upraded to Z06 wheels.
Wheel/tire upgrade is the BIGGEST expense involved in doing the C5 brake upgrade.
GET ADAPTERS FROM "EDSALINAS" . . .he is the adapter bracket MAN !!!!
You'll find his adapters out on eBay.
Thanks Jim.......
:cheers:
$ 2295.95
You could also get Alcon or AP, but we're talking big $$$ now.
A set of 2 Alcon B type four piston calipers complete with rotors and all hardware is only $1500 for a mustang aplication though.
But I belive that brembos up front and the stock J55 in the rear is more than enough. :thumbs:
[Modified by Darkness, 1:31 AM 10/17/2003]
