Code 34???
Old Oct 16, 2003 | 10:13 AM
JJ 86's Avatar
JJ 86
Default Code 34???
If the MAF sensor was bad would it start and run poorly with it unpluged or would it still start then die? Just replaced the relays (not to long ago) behind the battery.
Old Oct 16, 2003 | 10:34 AM
vader86's Avatar
vader86
Default Re: Code 34??? (JJ 86)
Usually you can tap the MAF with a screwdriver and disconnect it and the engine will run slightly better, though not always.
Sounds like its time to replace it.
Old Oct 16, 2003 | 10:43 AM
Unriced's Avatar
Unriced
During one of my troubleshooting epsiodes, I disconnected my MAF and the car
ran like crap..And it threw a code... My one cent.
Old Oct 16, 2003 | 10:51 AM
Corvette0096's Avatar
Corvette0096
34 (1985-1990) Clean the throttle body. Check MAF connections. Replace MAF relay. Replace MAF Sensor. Possible ECM failure.
Old Oct 16, 2003 | 11:50 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Code 34??? (Corvette0096)
:iagree:
Old Oct 16, 2003 | 03:08 PM
JJ 86's Avatar
JJ 86
Well, so far its not the MAF sensor nor is it the burn-off relay. Still trying to locate the power relay. If this isn't it would there be any other sensors that will cause this particular problem? :banghead:
Old Oct 16, 2003 | 05:13 PM
vader86's Avatar
vader86
Have you cleaned the TB and IAC?
How did you determine that the MAF was still good?
The two relays sitting behind the batt are the power and burnoff relays, if you replaced those recently i would eliminate them, although a bad MAF could end up killing them and vice versa.
Otherwise its a connection, or the ECM.
Old Oct 16, 2003 | 11:50 PM
JJ 86's Avatar
JJ 86
Default Re: Code 34??? (vader86)
Well, just replaced both relays behind the battery along with the MAF sensor. Now no code 34 but it still starts up and then dies unless giving it gas then it runs. My next step will be to remove the ECM and replace it since it has a lifetime warranty. Also the IAC and the throttle body were cleaned last month when i was having the same problems. :banghead:
To Code 34???
