Tranny fluid dripping...
Old Oct 16, 2003 | 11:24 AM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default Tranny fluid dripping...
I've had the pan off twice and the bolts tightened 3 times and the thing STILL leaks A LOT--about a quart each month!!! That's amazing to me. I know about the problem of the pan possibly being bent a bit and the problem of the gasket being compressed too much (overtightened bolts), but A QUART EACH MONTH??!! What's up with this? *This is on an '84 with 148,000 miles. Sound powertrain...except for the leaking!!! :crazy:
Old Oct 16, 2003 | 11:42 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Tranny fluid dripping... (C-4 Cross Fire)
Are you SURE it's leaking around the pan?
There ARE a couple of other places it "could" leak...it ALL ends up on the pan because that's the lowest point.
Old Oct 16, 2003 | 05:23 PM
vader86's Avatar
vader86
You sure its the pan, when the front seal blows, it'll almost pour out, youll have noticeable puddles.
Old Oct 16, 2003 | 05:26 PM
MyX10sion's Avatar
MyX10sion
Could it be coming from the shift shaft? Clean the area around it to see.
Old Oct 16, 2003 | 06:39 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I had the same type of problem on my '84. Then I went to http://www.jegs.com and bought a Deral Trans Pan. With cooling tubes and xtra capacity. Fluid runs cooler. Although I do use a special cooler for the trans also.
Have not had problems since, now over 2 years.
Don't know if this will help you. But just an FYI. Best $79.95 I've ever spent on the automatic.
tony
:flag
[Modified by oldace84, 3:40 PM 10/16/2003]
[Modified by oldace84, 3:41 PM 10/16/2003]
Old Oct 16, 2003 | 11:11 PM
jsinga's Avatar
jsinga
Default Re: Tranny fluid dripping... (oldace84)
My 87 had a pita leak around the dipstick tube up front.
JS
Old Oct 17, 2003 | 07:44 AM
robtx's Avatar
robtx
Default Re: Tranny fluid dripping... (jsinga)
I had a similar problem, you might want to check the seal around the shift linkage.
To Tranny fluid dripping...
