Front Spring spacers ???
Old Oct 19, 2003 | 10:06 AM
LD85's Avatar
LD85
Default Front Spring spacers ???
Can you put the rubber spacers or some plastic spacers back into the front spring after having cut them out?
Does someone make the spacers?
Old Oct 19, 2003 | 11:47 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Front Spring spacers ??? (ld85)
So you want to raise the front up some huh? I'm not sure about this one, not to many people talk about going in that direction.
Some one 'll chim in before too long that knows what there talking about, obviously I don't............ :leaving:
Old Oct 19, 2003 | 01:24 PM
Raistlin's Avatar
Raistlin
When I lowered my car, I cut off the rubber spacers and epoxied a piece of cutting board in it's place. I used a piece 3/8" thick because there is a 1/4" depression in the frame above the spring spacers and I didn't want the spring resting on the frame.
I wouldn't feel comfortable glueing 2 pieces together, so It would be best to buy material in the thickness you need. Any polyurethane or similar material should be fine. It should be soft enough so it doesn't damage the spring.
Thanks to, I hope I recall correctly, member Agent86 for the cutting board idea.
Oh, just had another idea. The stock setup uses 1/4" metal spacers with holes for the bolts to run through. You might be able to get some from people who are lowering their cars. I no longer have mine, or I'd offer to send them to you.
:cheers:
--steve
To Front Spring spacers ???
