Throttle body cleaning.
Old Oct 19, 2003 | 10:01 PM
JIMBO7's Avatar
JIMBO7
Default Throttle body cleaning.
I've got that sticking feeling when opening the throttle. I'm going to remove the TB to clean it.
Who has the stuff?? The TB gasket, TB topplate gasket, the IAC gasket and the TB cleaner? I hate having to go to 2 or 3 places to get it all together.
Ideas?? I'm in Massachusetts. :rolleyes:
Old Oct 19, 2003 | 10:11 PM
autotech's Avatar
autotech
Default Re: Throttle body cleaning. (JIMBO7)
Be careful with the gakets and reuse them, it will seal just fine. To heck with throttle body cleaner, that is for cleaning them without pulling it off, which does not work near as well. Get some B-12 and and old tooth brush, does a great job - $3.00...
Old Oct 19, 2003 | 10:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Don't make it too difficult...just swab out the TB and plates with TB cleaner on cotton swabs.
Even if you remove the TB, leave the top and bottom plates in place. If you want to clean the IAC bore just remove the IAC and swab out the bore.
I expect the TB to IAC plate gasket may be a dealer item but the others are available in a Fel Pro kit from Auto Zone.
Old Oct 20, 2003 | 09:08 AM
sraft's Avatar
sraft
Default Re: Throttle body cleaning. (65Z01)
I did this a few months ago. GM gas a gasket kit that includes the top cover gasket, and the IAC plate gasket. The TB to intake gasket is not included - you have to order it seperately (why they don't make an all-inclusive kit is beyond my comprehension). The GM prices are a rip-off, so if you can get FelPro gaskets, you'll save a bunch.
PS the IAC had an o-ring which I cleaned, greased and resued.
[Modified by sraft, 9:09 AM 10/20/2003]
Old Oct 20, 2003 | 02:38 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Throttle body cleaning. (sraft)
Advance Auto Parts stores stocks a gasket set for the throttle body, too. I purchased one this past summer when my throttle body got cleaned at CI-IV.
Old Oct 20, 2003 | 03:04 PM
Topless87's Avatar
Topless87
Default Re: Throttle body cleaning. (onedef92)
Yep, got the entire gasket set including top, bottom, back and IAC gasket from Autozone for $4.95. So I went ahead and did the whole thing. A tooth brush and a can or two of TB Cleaner, not carb cleaner.
Also, squirt a little WD-40 in the throttle plate bushings after you are done. The TB Cleaner can wash a little grime into them and that will ensure it is free. Then adjust your TPS and Base Idle per the tech tips in the forum and you are all set!
:cheers:
Old Oct 20, 2003 | 04:18 PM
korvette4u's Avatar
korvette4u
check for more info: https://www.corvetteforum.com/techti...=195&TopicID=2
Old Oct 20, 2003 | 07:57 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Throttle body cleaning. (Topless87)
:iagree: :thumbs:
To Throttle body cleaning.
