Question regarding Drive vs Overdrive in 4L60E
Old Oct 21, 2003 | 12:47 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Question regarding Drive vs Overdrive in 4L60E
Does the overdrive operate "on top of" the first three gears or is it just the fourth gear? In other words, if I have the gear selector in (D) rather than D, is the overdrive always engaged or just "available" as the fourth gear if needed? Thanks...
[Modified by tobijohn, 12:49 PM 10/21/2003]
Old Oct 21, 2003 | 02:22 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Question regarding Drive vs Overdrive in 4L60E (tobijohn)
Unlike the 4+3 manual transmission, the overdrive in the 700R4, 4L60, and 4L60E, is a fourth gear. Any "shift" you may feel, or drop in rpms in other gears is due to the converter locking up. Good luck, and...
RACE ON!!!
Old Oct 21, 2003 | 06:42 PM
tobijohn's Avatar
tobijohn
Bench Racer
Default Re: Question regarding Drive vs Overdrive in 4L60E (CFI-EFI)
Thank you! I suspected as much by punching it from a standstill in both and not being able to tell any difference...
To Question regarding Drive vs Overdrive in 4L60E
