Head Job
As far as the gaskets...If it's 91 & older 350 (L98), you just need 350 Chevrolet gaskets.
If it's 92 & above...you need LT1 gaskets.
Easy way to tell...If there is a belt on the waterpump = L98...no belt = LT1.
Checking the heads for warping is paramount, as you indicated. Just about any machine shop can check for, and correct warpped heads. Have them show you how they check them. Then, beg, borrow, or steal, a straightedge and check your block, too. The block is beefier and more stabile than heads are, especially aluminum heads, but don't assume that if the heads are good or not too bad, that the block is OK. If the block has to be surfaced, you've got a REAL job ahead of you. Good luck, and...
RACE ON!!!
:lolg:
Glad to hear you've decided to tackle this yourself. Good for you. You can do it.
A couple of pointers:
If you don't have it already, you'll need a good set of tools and a Haynes manual.
Buy a box of Glad bags for your fasteners (except the head bolts)
Grab a Sharpie. You'll need this to label the bags.
Pick up Nitrile gloves (about $11.00 for 100) this will keep your hands clean
A torque wrench is a great thing. Sears will sell you one for $59.00, or you can pick a crappy one up from Harbor Freight. Make sure it reads in FOOT POUNDS, and not inch pounds.
Take notes, and if you have a digi cam or other cam, take pictures as you go, to document where stuff goes. This can bail you out when you go to put it back together, and can't remember what goes where.
Pick up a good breaker bar. You'll need it.
Keep this forum nearby and take your time. If you feel yourself getting tired or frustrated, walk away. This has saved me from more fiascos than anything else. Failing to do this, has caused me more frustration than anything else.
This is my advice. Others will chime in with more.
:cheers:
[Modified by joeveto, 8:14 PM 10/21/2003]
It's a long story, but I also had head gasket problems. An interesting thing about the stock 113 heads, one edge of the combustion chambers has very little surface for the head gasket to seal against, so Wayne welded a small bead around the edges and then machined the heads flat.
Other things to consider:
You may want to get a three angle valve job done, although I've heard a fresh valve job on a worn motor may cause excessive oil consumption. I did this once and had no problems.
If the valve guides are worn, you may want to get them replaced.
You may also want to discuss getting the heads pocket ported especially if you put a more aggressive cam in. After inspecting my heads and checking out the specs on the new cam (TPIS ZZ-9, in this case), Wayne said porting will definitely produce some good gains. I said go for it.
It's good to see you doing the work yourself, it will take some time, but it will save some money, and in the long run you'll have a helluva lot better car. Good luck.
:lolg:
:cheers:
Good luck - we know you can do it!
